0 Members and 121 Guests are viewing this topic.
exnihiloest
Quote from: ltseung888 on August 14, 2008, 07:11:40 PM
Extracts from the coming book
Chapter on designing the Magneto Propulsion Unit (MPU)
In the above figure,
(1) The 4 rectangles represented by a are programmable electromagnetic coils.  They are stationary in the inner cylinder b.
(2) The magnetic ball c can move within the cylindrical grove d powered by magnetic attractive forces from the electromagnetic coils a.  Such movement and set up is effectively a lead-out-energy device.  Some of the lead-out-energy can be extracted via the programmable electromagnetic coils a.
(3) The magnetic ball c essentially glides or rotates on the surface of the stationary inner cylinder b.  The speed can be very high.
(4) When the magnetic attraction force is cut (or turned into repulsion), the magnetic ball c will fly away in the tangential direction along the angle shaped e.  It will hit the surface of e providing an effective force to move the unit downwards in this case.  If the angle shaped e is moved to a different position, the effective force can be in a different direction.
(5) The magnetic ball can be attracted back to repeat its circular motion.
(6) Two of these MPUs can work in unison to provide smooth motion to the vehicle.
When the ball is rolling around the lower half-circle, the centripetal force acting on the ball lead to a reaction force onto the cylinder via the coils and magnetic forces. The resulting force on the cylinder is in average in the direction of the arrow.
When the ball is rolling around the upper half-circle, there is an equal force acting onto the cylinder in average in the opposite direction of the arrow.
Thus for each turn, the resulting forces along the arrow are perfectly balanced and we have not to account for their work.
But when the ball is released and hits e, its last half-turn was upper and not balanced by the lower one, thus the average force acting onto the cylinder was in the opposite direction of the arrow, counter-balancing the work of c hitting e.
No motion can be expected from such vehicle.
It is well known that in a closed system, circular motion can't be converted into linear motion. Either you have to prove our models of physics laws are wrong or you have to show us new and unknown phenomenon in physics. You can't expect for revolutionary phenomenon using only basic and simplistic designs with conventional objects and forces which are modelizable with lagrangians or hamiltonians.
chrisC
Quote from: exnihiloest on August 25, 2008, 09:42:00 AM
Ah, don't forget Exnihiloest, Tseung has not passed his 'O' level physics yet. That's why he keeps on postulating all kinds of crap with no bearings to known physical laws. It's all in his head. Because he doesn't know how to use a drill, he is not able to build a prototype to demonstrate his Tseung-Lee theory of unknown phenomenon. Sad to say, this astounding discovery will never be known.....
cheers
chrisC
Top Gun
Please note that the magnetic ball c is made to rotate faster via the action of the electromagnetic coils.  With the extract supply of energy, the system cannot be closed.
In addition, there is a net attractive magnetic force from the action of the electromagnetic coils attracting the mganetic ball towards the center - the required centripetal force to keep the magnetic ball c from flying away.
Note that the electromagnetic coils are powered by Pulsed DC current.  This means that they will exhibit North Pole, No Pole, North Pole, No Pole, North Pole, etc. The permanent magnetic ball c always have magnetic South pole pointing towards the center.  (You may be confused by assuming a rolling actions.  For ease of understanding, consider sliding action.  Or think of it as the motion similar to a chained-ball.)
The physics described here cannot be wrong.  I shall describe the pulsing circuit in a separate post.
Top Gun
The Direct Current pulsing circuit applied to an electromagnetic coil.
(1)   When a DC current is passing through an electromagnetic coil, the electromagnetic coil will exhibit the properties of a magnet with one end acting as the North Poles and the other end acting as the South Pole.
(2)   If the DC current is stopped, the electromagnetic coil will start to lose its magnetic properties.  In the perfect case, the magnetic properties will disappear and the electromagnetic coil will show No Pole.
(3)   If the DC current is pulsed, the electromagnetic coil will show North Pole, No Pole, North Pole, No Pole, North Pole, No Pole, etc.
(4)   Consider the wheel (Pulsed-rotation1.jpg), the permanent magnet PM1 will be repelled causing a clockwise rotation force if the electromagnetic coil EC showed properties of a North Pole.  When the permanent magnet PM2 approaches the electromagnetic coil EC and if EC still exhibit the properties of a North Pole, there will be a repulsion causing an anticlockwise rotation.  However, if the electromagnetic coil EC has No Pole, there will be no repulsion.  When the permanent magnet PM2 moves to the position of PM1, the electromagnetic coil EC shows property of North Pole again.  There will be repulsion in the clockwise direction.
(5)   This explains the need for a pulsing DC current to rotate the inner cylinder in the clockwise direction.  The Newman, Bedini, Adams, Liang and the 225 HP pulse motors all use the above feature.  The pulsing rate must match the rotational speed for an effective operation.
Top Gun
In Pulsed-rotation2.jpg, the electromagnetic coil is used as a collector coil.  When a permanent magnet moves, its magnetic lines of force will interact with the electromagnetic coil to produce current.
In the Lee-Tseung lead-out theory, they do not use the concept of back EMF or zero point energy to explain the source of energy.  Thus the collector coil can be a totally different electromagnetic coil similar to the Adams motor.
The 225 HP Pulse Motor is clever in that the electromagnetic coils can be programmed to be either pulse coils or collector coils.
There is no magic, no back EMF and no zero point energy.  Everything is ?O-level Physics?.  It is just a matter of extending the concept of the pulsed pendulum to a pulsed balanced wheel.
