0 Members and 28 Guests are viewing this topic.
ltseung888
Quote from: Top Gun on January 23, 2009, 04:05:10 PM
An improved combined lead-out energy flying saucer.
The Tong Po Chi device with the top taken off clearly showed that the momentum from a moving permanent magnet could be transferred to the tube via an electromagnetic coil fixed to the tube.
The attached diagram uses this technique to provide the upward force.  It is so much simpler.  Selective amount of force can be transferred.
This can also be tested in the horizontal direction first.
Brilliant!  Most of the difficulty related to the Bill Fung design has been removed.
Shall do additional testing to confirm feasibility of this design.
[/quote]
ltseung888
Coil as collision mechanism
The Tong Po Chi device with the top taken off shows that we can use the electromagnetic coil as the collision mechanism.  The permanent magnet never collides with any solid surface and yet will not leave the tube.
When the permanent magnet moves up towards the coil, (position 1) there is magnetic attraction, which helps to move the magnet faster.  When the permanent magnet leaves the coil, (position 2) the force will be downwards.  This keeps the magnet from leaving the tube.
However, the momentum of the permanent magnet was changed.  We can think of it as transferred to the coil and tube.  That provides an upward force acting against gravity.
Thus in the donut type arrangement where we have many magnetic balls passing through the coil, each passing effectively provides a pulse force in the upward direction.  This is the magic trick!
critic
Quote from: ltseung888 on January 23, 2009, 10:56:23 PM
This is scientific research at its best.  The many theories and experimental results are laid out.  Then there is the flash of inspiration.  The awkward mechanical design was replaced by the simple electromagnetic coil.  The new design is so simple that it must work.  It took over a year to find this improvement but the wait is worth it.
I look forward to the experiment confirmations.
Happy Chinese New Year.
Top Gun
Comparing Chemical Energy and Electron Motion Energy
In the Lee-Tseung theory, there was much mentioning of Electron Motion Energy.  Lee and Tseung claimed that we can lead out electron motion energy.  Electrons are associated with every atom.  They can be imagined as circulating around the nucleus.  Changing their clustering, their orbits etc. will result in changes of energy shown as light, magnetism, electrostatic phenomena, electromagnetic waves etc.
We are familiar with chemical energy.  Different compounds have different electron clouds around them.  When one compound changes to another, the associated electron clouds will be different.  That is chemical energy.  We may have to supply heat to cause the chemical reaction.  The chemical energy is usually released as heat or light.  In reality, it is a form of electron motion.
In the Lee-Tseung theory discussions, much is focused on magnetism.  Magnetism is due to electrons in circular orbit.  If they are aligned in a particular direction, we can detect magnetism.  The magnetic material will influence the electron distribution or alignment of other nearby materials.  Lee and Tseung claim that these distributions have different associated energies.  When we use suitable oscillations, vibrations, rotations, flux changes, etc., we can lead out such associated energies.  There is no violation of the Law of Conservation of Energy.
Lee and Tseung claimed that there is constant interchange of electron motion energies such as electromagnetic waves, black body radiation etc.  The lead-out energy used to do work can be replenished via such interchanges.  Lee and Tseung have not defined the exact energy content of any electron distribution.  They claimed that since the electrons are associated with every atom, they are effectively using atomic energy.  They do not use the energy from the nucleus but use the energy from the electrons.
I find their explanation logical and fall within the knowledge of existing physics.  Your comments are welcome.
chrisC
Quote from: TinselKoala on January 23, 2009, 10:24:45 AM
Put your money where your mouth is. I am willing to do so.
If Lawrence can tell the truth, we don't need some 400 pages of crap!
Snake oil sales people can only sell snake oil!
cheers
chrisC
