0 Members and 76 Guests are viewing this topic.
utilitarian
Quote from: Top Gun on February 03, 2009, 05:14:26 PM
Try the combined twin device M and N double jump when ready.  That is the definitive experiment.
You are right about the double-jump being definitive.  If the double-jump prolongs the jump, I will gladly eat my hat, crow, whatever you call it.  So let's see it.
ltseung888
Quote from: utilitarian on February 03, 2009, 05:48:20 PM
You can eat WBLT as main course.
Pay careful attention to the following ten posts.
The first one is the picture taken at Dr. Raymond Ting's Office.  He has successfully achieved the double-jump.  The existing version uses human as the Timer and there will be disputes as the video could not pinpoint the exact moment of sending current.
Dr. Ting is working on a Timer version to make it more scientific and easier to reproduce.
Here is his picture with his many achievements.
ltseung888
This second picture will probably make Dr. Ting an important figure in the development of the flying saucer.
He used foam material to separate the two Tong Po Chi device tuned for Attraction jumping.  The two devices must be separated by a reasonable distance because the two permanent magnets in the two tubes will interact with each other.
He chose foam material because it was light.  He also used the minimum height plastic tube to reduce the weight M2.  A relatively large and heavy magnet taped to a plastic tube was used.  Thus M1 is much larger than M2.
ltseung888
The third pictures shows the basic equipment used.
Dr. Ting tried both batteries and DC power supply.  Both worked.
Dr. Ting prefers the battery as it is lighter.
He has tried at least 5 types of copper wire for the Coil.  He also tried 20, 60, 80 100 turn coils.  The final double-jump experiment was done with 20 turns of number 18 as that seemed to provide light weight and sufficient magnetic attraction.
He decided to use the magnetic attraction jump as it is less complicated than the combined attraction-repulsion arrangement.  The magnetic attraction can achieve a higher jump than the repulsion configuration.
ltseung888
The fourth picture is the device in horizontal repulsion mode.
Some forum members thought that when they applied Newton's Laws, the horizontal configuration should not move or at most moved to a center of mass mode.
The experiment proved that the device had little motion until the magnet hit the restricted end and jerked with significant movement at that instant.
The single repulsion experiment points to the correctness of the Tong Po Chi horizontal arrangment where the magnet is pulse repelled by two coils with unequal turns.  There is a net movement or propulsion force.
