hansvonlieven
I said unidirectional force not hopping pogo stick.
Hans von Lieven
Top Gun
When one stays until experiment 09 and 10 in the mini-workshop, he will find the sweets.   See the following diagram.  That is one of the key data collection experiments.
The large unbalanced force can be produced in any direction.
Top Gun
Quote from: Devil on February 10, 2009, 08:08:40 PM
For those who still do not understand the Tseung flying saucer or WBLT, recite the following 666 times.
"I can generate unbalanced force from a closed system.  The secret is to use the secondary events where there are unequal exchanges of energy or momentum."
For those who still cannot understand, welcome to my warm home.
I shall try to explain the concept of secondary events more.  In Experiment001, there were two magnets repelled in opposite directions.  The primary event can be thought of as the passing of current to provide magnetic repulsion.  Action = Reaction applied and the two identical magnets travelled in opposite directions.  One magnet hit a solid surface.  If we assume that the collision were elastic (no loss of energy), the force would be equal to F1.  This was the first secondary event.
The other magnet hit a padded surface.  That surface would deform and lengthen the time for the velocity of the magnet to slow down or reverse direction.  The Force F2 would be less than F1.  This was the second secondary event.  The difference between f1 and F2 is the unbalanced force claimed by Tseung.  This is strictly Newtonian Physics.
Experimentally, this can be observed but the effect is small. (The multiple videos on Experiment001 will confirm that.)
Experiment002a-c were interesting as they emphasized the same point in a very striking manner.  Experiment002a repelled the permanent magnet like a gun.  The permanent magnet was shot out to a few feet.  The tube recoiled and there was a large swing of the pendulum.  Experiment002b prevented the permanent magnet from leaving the tube by blocking the tube with a solid surface.  The recoil of the tube was almost exactly balanced by the collision of the permanent magnet with the solid block.  The Pendulum hardly swung.  Experiment002c was the same as Experiment002b except a soft, yieldable surface was used.  (That surface was provided by a loose tape.)  The video clearly showed a swing in the direction of the recoil.
These two experiments clearly verified the Tseung assumption that an unbalanced force can be produced from within a closed system
Mr. Tong Po Chi was brilliant in replacing the 2 magnets and 1 coil arrangement with the 2 coils and 1 magnet arrangement.  He found that a much larger unbalanced force could be produced.  Further investigations by Dr. Raymond Ting confirmed that.  Two additional characteristics of the electromagnetic coil were researched.  One is that an attracting arrangement could replace the collision.  The other is the collecting coil property that converts the kinetic energy into electrical energy.  These two characteristics helped to produce a much larger unbalanced force than what was possible with pure mechanical means.
The large unbalanced force is now demonstrated in the various Experiments.  Much more testing and tuning could be done to further increase this unbalanced force.  Theoretically, the unbalanced force can be greater than the weight of the tube and magnet.  So far, the unbalanced force is in pulses.  However, multiple pulses from multiple tubes would result in a more or less constant force.
Thus pulsing current to a suitably configured device will elevate it from the ground.  That is the magic behind anti-gravity.  The trick is to design the suitably configured devices.  (Mr. Tseung believes that USA, China and other Countries have already designed and built such devices.  The many UFO sightings are related to such top-secret crafts.)
chrisC
Quote from: Top Gun on February 13, 2009, 01:13:39 AM
I shall try to explain the concept of secondary events more.  In Experiment001, ....
Dear Top Dork:
Get some more sleep and take your pills!
cheers
chrisC
Unbelievable. It amazes me that people who apparently cannot think their way out of a paper bag can actually do their shopping, use a computer, etc.
The balloon experiment suggested by Hans is a good one, easy to do, and it is pretty clear that the children playing with their solenoid toys won't do it. Because THEY CLEARLY KNOW that it will produce a null result, thus FALSIFYING the Lee-Tseung Lead-Out conjecture.
Yet again.
And it's clear from those videos that no unbalanced force is being produced, except when a force vector is generated that doesn't go thru the suspension point or the CG of the system--then it tries to rotate.
