Top Gun
Quote from: Pirate88179 on April 04, 2009, 11:36:01 PM
Yes, welcome back Lawrence, I was getting a little worried about you.
My Bedini replication does not use a reed switch at all. It uses a 2N3055 transistor.
In the overview diagram below, A are coils that can be driver magnets, collector magnets or null effect devices.  Coils A will not rotate but will react to the Pulsed DC curent. Coils A will be stationary on the outer cylinder.
B are permanent magnets that will be pulse driven by the A coils.  They will rotate the inner cylinder.
C is the extremely important sensing device that will determine when to apply the DC Pulse Current.
A possible operation cycle is as follows:
(1) The inner cylinder is started to rotate by hand.
(2) The device is turned on.  When C detects that the permanent magnets have just passed the central position corresponding to the Coils A, a Short DC Pulse Current is applied to rotate the inner cylinder in the clockwise direction.
(3) The clockwise rotation of the inner wheel or cylinder will accelerate.  The pulsing rate will increase correspondingly.
(4) When a pre-programmed rotational speed is achieved, some of the Coils A will change from driving coils to collector coils.
(5) The collected electricity can be used to recharge the battery or do other useful work.
(6) The collected current or output energy is the sum of two energies - the input energy from the battery and the lead-out electron motion energy.
Thus one key element is the sensing device C that will help the computer program to provide more or less driving DC current.  The duration of the Pulse must be short enough so that there will be no unwanted repulsion to slow down the rotation.
This is the key difference between the 225 HP Pulse Motor and the Newman or Bedini motors.  There are many groups in China that understand this difference and are working on various prototypes.
Many expermenters just tried to replicate the Newman and Bedini motors without understanding the Lee-Tseung lead-out theory and many failed because they are not changing the Pulse Frequency or strength.
The advantages of the 225 HP Pulse Motor include:
(a) The Coils A and Permanent Magnets B can be in very close proximity as they are separated by two cylinders.
(b) The Pulsing rate can be varied in accordance with the rotational speed of the inner cylinder.
(c) The computer program can provide much more control.
(d) The output energy can also be obtained via the rotating shaft of the inner cylinder.  Mechanical power can be obtained directly.
(e) The Coils can provide direction independent magnetic fields.  Thus the motor can be tilted in different directions.  (This is one big advance over the IC driven Dr. Liang Motor.)
chrisC
Quote from: Top Gun on April 05, 2009, 12:23:10 AM
Isn't all these points getting a little long in the tooth? I would have thought, the brand name of 'Top Gun' is not fashionable anymore. You need a new name, something more fashionable.... maybe TOP DORK?
cheers
chrisC
Devil
With the description and the diagram, you have disclosed the secret of the Lead-Out Energy Machines.  It is like releasing the secret of the Atomic Bomb.  There is no turning back.  More than one country will have the Lead-Out Energy Machines.  Obama will become one of the greatest presidents of USA if the lead-out energy is developed to benefit the World under his term.
The man-made flying saucers will fly over the White House with many reporters announcing the event soon.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
hansvonlieven
Quote from: Devil on April 05, 2009, 04:21:22 AM
This blasted thing was supposed to fly over the Peking Olympics !!!!! (Sorry, the party version is Beijing.)
It never did !!!
How about a real demonstration? If it succeeds flying over Mogadishu unharmed I will buy it's real.
How about it Lucifer?
(or Beelzebub, Satan, Devil, Sheitan, Horned Goat, Cloven Hoof or whatever else you may call yourself)
Why not fly the bloody thing over the Vatican?
That would be a good test too.
Don't talk about it barbed dick, do it !!!!!
Hans von Lieven
BTW: For those of you that don't know, according to medieval doctrine, the Devil has a barbed dick to make intercourse excruciatingly painful.
Top Gun
From Wikipedia, the free encyclopedia
A solid state relay (SSR) is an electronic switch, which, unlike an electromechanical relay, contains no moving parts.  A photo-coupled SSR is controlled by a low voltage signal which is isolated optically from the load. The control signal in a photo-coupled SSR typically energizes an LED which activates a photo-sensitive diode. The diode turns on a back-to-back thyristor, silicon controlled rectifier, or MOSFET transistor to switch the load.
It is a matter of selecting the correct SSR for the Pulse Motor prototype.  It helps to have experts who are already familiar with the SSR.  Learning from square zero is not always the best strategy.
Any suggestions?
