0 Members and 106 Guests are viewing this topic.
Forever
I just finished experiment 1-Generating an unbalanced force from within a closed system. I used an electromagnetic coil to repel two identical weak magnets to the opposite end of a tube with unequal padding surfaces. The result confirms the theory. The movement is towards the hard surface side. The following picture shows the equipment I used.
I also used the trick of re-magnetizing the weak magnets to regain the experimental results.
chrisC
Quote from: Forever on April 28, 2009, 02:00:45 AM
@ Forever
Do you think that experiment will help you pass 'A' level Physics?
I hope you'll learn some real Physics. Lawrence's Physics is pre-'O' Level standard.
cheers
chrisC
Top Gun
I am glad that you can prove a powerful theory with such a simple experiment.  Once the fact  that - an unbalanced force can be generated from within a closed system - is proven, accepted and applied, the man-made flying saucer is reality.
The trillion dollar space programs will take new directions.
Many traditional scientists will not think of the trick.  It is extremely scientific once it is explained.  Some stupid person will say that if the experiment is not reproduciable in the same manner, the experiment must be a hoax.  I am glad that you explained it so clearly.
chrisC
Quote from: Top Gun on April 28, 2009, 09:11:30 AM
I am glad that you can prove a powerful theory with such a simple experiment.  ....
Dear Top Dork:
Congratulations on your very simple experiment. It's so simple and ready to change the world for good. We're waiting patiently for the flying saucer you promised.  Right now your very simple experiment can't even hop off the ground and stay afloat 1 cm!
Maybe my great grandchildren will live to see it?
cheers
chrisC
Paul-R
Quote from: chrisC on April 28, 2009, 02:04:50 AM
@ Forever
cheers
chrisC
You are profoundly ignorant, chrisC. What is so sad and pathetic is that you do not care to learn
and improve. You are a waste of Stefan's valuable bandwidth.
