0 Members and 108 Guests are viewing this topic.
ltseung888
Conversation with Mr. Lung in Shenzhen
Day 1  The prototype arrived in Shenzhen.
Lung: “It arrived.  I am coming over now.”
Tseung: “I have not even unpacked and test it yet.”
Lung: “It does not matter.  I shall help you to unpack.”
Within minutes, Lung arrived.
Lung: “There are pieces falling out from the prototype.  There are also loose wires.  You must have had a rough journey.”
Tseung: “We did not have packing material.  I just hand-carry the prototype in a large paper shopping bag.  It went through taxi, underground, train, underground and over half a mile on foot.”
Lung: “I can help to do the testing.  There are over a dozen places that can go wrong.  Do you have extra spares that we can swap?”
Tseung: “No.  But I know I can get almost every component in the electronics stores in Shenzhen.”
After an hour messing around, Mr. Lung was frustrated.
Lung: “A non-working prototype is not worth anything.  Are you sure that it has been working?  How come you cannot fix it?”
Tseung: “I shall purchase the various parts and make it work.  I shall phone you when it works again.”
Day 2
Tseung went to the electronic stores the next morning.  After replacing some parts, including a burnt relay, the prototype worked.  Mr. Lung came.
Lung: “Does it always require the finger to start it?”
Tseung: “You can try.  If the magnet were in the just-right position, the turning of the switch would start it without the finger motion.  Otherwise use you finger.”
Lung: “It goes to almost 70 volts AC on 12 collector coils?  Can I use a smaller battery?”
After trying, Lung: “It worked.  However, the voltage was only 30 volts AC.”
Tseung: “We need to improve it before it can generate 5 KW.  We know that it can be done as the 225 HP pulse motor from USA could generate over 20 HP with one slice.  I shall post the suggested improvements on the Internet.”
Lung: “If the 5 KW prototype works, every home will purchase one.  The value will be in multi-billions.  Why are you sharing the secret with the World?  Some one will steal your idea.”
Tseung: “I do not mind someone stealing the idea so long as the World benefits together.  The educational toy that conclusively demonstrates overunity with lead-out energy will make you rich beyond your wildest dreams.  Focus on getting that produced.”
ltseung888
Conversation with Ms Hung, a housewife
Tseung: "I have connected all 24 coils.  The reading is now 100 volt AC."
Hung: "That is great.  The needle points to 100.  Does that mean I do not need to pay electricity bills from now on?"
Tseung: "Not so fast.  This is only a proof-of-concept prototype.  You need to wait a few weeks longer."
Hung: "I shall cook you a very nice dinner with your electricity when that happens."
Tseung: "Thank you in advance."
ltseung888
The prototype managed to light up an LED.
It failed to light up a 50 watt light bulb.  The wheel slowed to a halt.  The actual output is somewhere between a few watts and less than 50 watts.
chrisC
Quote from: ltseung888 on June 09, 2009, 09:28:00 AM
Keep talking to yourself and to your strange fellows. We'll take serious notice when you are able to show convincing scientific proofs your 'O' level experiments produce O.U.
cheers
chrisC
ltseung888
Technical session with the Students
Jacky: “Why should we have two paths?  The Tong Po Chi and the 225 HP Pulse Motor.”
Tong: “It was hoped that the Tong device would generate 220 Volts AC and power household appliances in one single step.”
Miller: “The test with one single coil yielded a 10 volts AC.  With 24 coils, we hoped to get 240 volts AC.  Experimentally, the best we could get was 100 volts AC so far.”
Tseung: “The initial design called for a maximum of 2 Amp DC as input.  The actual prototype used 10 Amps.  What is the reason for the change?”
Tong: “Initially, we used the same type of Coil for Pulse and Collector.  However, our design is different from that of the 225 HP Pulse Motor.  The same type of Coils could not provide the Drive.  We then used thick coils, oval shaped coils etc.  One of them worked.  We know that other configurations might work even better.  However, we were under pressure to show something working.”
Forever: “It worked.  We were able to demonstrate the device on May 28, 2009.”
Tong: “In exploring the unknown, any path is a good path.  Document what has been learned.”
Tseung: "Share it with the World."
