markdansie
@Robbie and Paul
Interesting comments. You are most welcome to come to my place and see the dozens of projects (especially hydroxy devices) I have built. However I know my limitations so when it comes to testing claims I arrange the people with better qualifications than I have to do the testing and give advice. One project recently that appeared on this forum that showed great potential (and still does) I facilitated a physicist and electrial person to visits and do tests. In the process the inventor was taught how to correctly read power in and out and was given the guidance needed to move forward and do things correctly. (for this I asked for no reward) The inventor was appreciative of this and took the advice in good spirit and making progress.
In some cases I assist or put people into contact with the money people (without me even having to receive anything) to progress their projects.
i do not restrict myself to forums, I am happy to take on large companies and dispute claims that are not real and encourage others that are.
Above all, I have respect in that very rarely anyone can pull the wool over my eyes. That's why I am often engaged to organise testing on behalf of investors.
I also come here because there are many interesting people and projects to follow. People like Jenna, Bill and many others do great projects that are fascinating and progressing all of our knowledge.
I guess what I am saying ,if it wasn't for people like me you might still be spending a lot of money building Mylow devices.
I also acknowledge that everyone has a role including people like yourselves. After all I need to be made accountable as well and I welcome your criticisms of me. I am far from perfect, and have blown a lot of money myself backing the wrong projects over the years.
I have made some great friendships with people and many enemies. I find it difficult that often when testing a device someone has put years of work into and it doesn't work how they thought it worked, they tend to shoot the messanger.
As always, thank you for your comments, and I do listen to them and learn. Hopefully I can become a better person by doing so.
However, if I see a scam or unsupported claims I will act in a uncompromising manner. I have seen far too many people have their lives destroyed by investing in devices that have not been fully scrutinised.
Kind Regards
Mark
teslaalset
Quote from: markdansie on October 27, 2009, 02:35:06 PM
Thanks for reflecting your view on yourself. Very educating.
Devil
What can go wrong now?
Tseung and Tong, think carefully what can go wrong now?
1.   Can the Input voltage and current measurements be wrong
2.   Can the Output voltage and current after converted to DC be wrong?
3.   Can the recharging of the battery be wrong?
4.   Can your interpretation of the action of the proximity switch be wrong?
5.   Can your interpretation of the function of the magnetic wheel be wrong?
The most surprising result of your Lead-Out Energy wheel is that any load you put on could draw energy from both the Output and the Input 12V battery.   This means that any Load that can be driven by a 12V battery can be driven by your wheel and more.  When that Load is removed, the battery is recharged.  Confirm such behavior with meters and other indicators.  You need to invest in a good oscilloscope sooner or later.
Test the case of removing the battery after starting.  If the Output is definitely overunity, you do have a chance of another breakthrough and impress the layman.  All doubts will vaporize.
You have not mastered the mechanism to increase the Output Power to 5KW yet.  You are still behind the 225 HP pulse motor.
You will have experts from Six Universities in Hong Kong to examine, verify, test and confirm your overunity results.  Do not expect a quick report.  Your invention has extremely far reaching consequences â€" rewriting the Physics and Electrical Engineering Courses.  Expect to build a few more similar prototypes with the scrutiny of these experts.  All secrets will be revealed.
Your chance of becoming multi-billionaires will be gone!
There is a possibility that you will be bought out or simply silenced!  You and Lee Cheung Kin were left alone because the “Powerful” did not believe two retired old men could actually bring the technology to life.  They thought that a couple of debunkers and insulters could do the job.  Expect foul play before and at the Carnival.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
markdansie
Quote from: Devil on October 27, 2009, 04:25:29 PM
Yes to all of the above & one other thing you may not have considered. You might be diagnosed professionally with a multiple personality disorder and be introduced to your other selves.
I encourage you to keep trying with your research. However stop making claims until you can have your device tested precisely. PS have the other Universities agreed to test your device or are they just attending the same event???? credability does not come by association.
Kind Regards to you and your fellow personalities
Mark
robbie47
That probably won't work because the output is in the form of pulsed energy.
The input requires very specific timing. It would be a very large coincidence when input and output are required at the very same time slots.
