0 Members and 50 Guests are viewing this topic.
chrisC
Quote from: ltseung888 on December 08, 2009, 09:18:47 PM
Improving the prototypes
The first test is use soft iron rod as core.
The trick is to insert the soft iron rod AFTER the wheel has started rotating at reasonable speed.
If the soft iron rod was inserted BEFORE the wheel rotated, it would be attracted and attached to one of the strong magnets.
Now we are even more confident in reducing the weight and increasing the Output Energy.  COP can be even higher.
More tests will be done and a new design will result.  We can reduce the shipping charges when we send the prototype to Stefan.
Amateur nonsense!
cheers
chrisC
teslaalset
Lawrence, I see you are using solid iron rods.
You may even be able to improve that situation if you use laminated iron core.
Solid core will have Eddy Current losses. Those losses will be minimized when you use small diameter multiple iron rods that are put together as one core.
Remember Bedini makes them out of welding rods. Long thin nailes could do the job as well.
The best results can be obtained when you isolate each rod by using varnish or any kind of isolating coating before putting them together.
Paul-R
Quote from: teslaalset on December 09, 2009, 03:19:05 AM
Welders throw away the rod when it is down to 2 inches. Useful. The flux is already
burnt off.
What about sendust, metglas cores? Are they useful? Also, what about iron
filings isolated by being packed into varnish or gloss paint to form a putty
like material?
The Observer
Mr Tseung and other interested parties,
I'm so glad you are tinkering with Ferromagnetic Materials in you invention !
I started a thread entitled.
      Magnetic Permeability ... I can't find anyone talking about this !
              http://www.overunity.com/index.php?topic=4831.0
                                  There still isn't anyone talking about it as far as I know !
                                            Another curious note, this thread was visited over 3000 times since I last posted 1 year ago,
                                                   and not 1 person made a comment !!!
                                                           I wonder if the powers that be might have been interested in it !
Anyways,
Basically it all boils down to this.
A piece of iron turns into a magnet in the presence of another magnetic field.
To spell it out...
                           A coil with no Ferro in it produces a VERY WEAK magnetic field.
                           A coil with a Ferro in it produces a VERY STRONG magnetic field. (same current)
                                        This field is 5,000 to 1,000, 000 times the intensity without Ferro !!!!
                                              Holy Sh_t Batman !!!!
            I have found that most people have no idea why this is !
                           Quite simply, the Ferro has a VERY STRONG magnetic field that you can't notice,
                                   until another magnet comes along to reveal it.
                            Reason is the Ferro has Zillions of rotatable magnets pointed in all directions that cancels out.
                            In an external magnetic field... they line up to reveal the total of their magnetic fields.
                                          (Mag Field Coil) + (Mag Field Iron) = (Total Magnetic Field)
THE PIECE OF IRON IS A POWERFUL SWITCHABLE MAGNET... is the point
A speaker IS an over-unity device.
       Most haven't considered the energy it would take to run a speaker without the magnet or a Ferro inside the coil attached to the speaker cone.
        Think on this... build a speaker without Ferro/Magnet.
                                  You can do it...with just copper coils you know.
                                   But it would take orders of magnitude more energy to run.
                                    The difference between energies from Ferro Speaker vs non Ferro Speaker (same sound output),
                                            is the energy that Ferro adds to the system for FREE.
Thanks for reading.
Summary...
         I really think a knowledge of what Ferro's do and how they do it is vital to the Free Energy Researcher.
         The other vital in my humble opinion is Resonance.
Joyful Regards,
                           The Observer
