0 Members and 98 Guests are viewing this topic.
teslaalset
Status of my replication:
- the bike wheel with the build in alternator has arrived. I am a bit disappointed by the friction the alternator is causing, even without a load. But it has iron cores at its receiving coils.
- I have ordered a micro-controller kit  (Arduino kit). That has arrived
- A programmer for the kit is on its way
- Coper wire has arrived. 5 kg of 1.5 mm (AWG 15/16) wire
- Electronics to build a power stage to drive the coils is under design
- Next step is to order components and build a power circuit to switch the coil in a (micro) controlled way
- The proximity switch will be a IR led/sensor
No worries about wrong investments.
Mentioned earlier, the wheel can be re-used for my bike, which still has a traditional alternator attached at rim position (which doesn't work reliable when it's raining or snowing)
I will use the micro-controller, power circuit and the wire for replicating the hex controller of Bob Boyce.
This stuff will be used to replicate the TPU alike stuff build by watkykjy1
(you can find his experiments on YouTube)
ltseung888
Quote from: teslaalset on December 13, 2009, 05:37:42 AM
Lawrence, I don't see the sinus shape right after the spike at the oscilloscope picture compared to what you have drawn in the slide, so maybe you should correct your slide.
There is no need to correct the slide.  As I mentioned, the actual shape of the Input Voltage varied with the setting of the proximity switch.  We shall do a video in the next few days.
It looks like you will not be replicating my set up exactly.  There are advantages and disadvantages.  The advantage is that we are likely to learn something new.  The disadvantage is that we have more new parameters.
Good Luck.
teslaalset
Quote from: ltseung888 on December 13, 2009, 09:20:59 AM
Good Luck.
Ok, I will look forward to your new video.
I wonder what pulse shape corresponds with a situation where COP > 1
I aim to replicate your principle, not your machine, so indeed we might learn something new maybe.
Please, keep in mind that your wheel is giving a lot of air loss as well as it turns. You better cover it from the sides as well.
ltseung888
Quote from: teslaalset on December 13, 2009, 09:48:44 AM
I aim to replicate your principle, not your machine, so indeed we might learn something new.
Remember that the principle is Lead-Out Energy.  You will mainly lead-out magnetic (electron motion) energy.  In order for that to happen, you need an electromagnetically unbalanced wheel (or non-constant rotating wheel) and a Pulse Force at the right time.
We shall see how your set up adheres to the above principle.   Have fun.
Top Gun
A Christmas Gift to the World
Mr. Tseung,  your 1 watt overunity device is ready and has been demonstrated to over 25,000 visitors via the two Open Shows in Hong Kong.  If you really want to benefit the World, why don’t you provide a free video showing all the components, all dimensions and all construction details.
I know that you have not solved the loopback problem yet.  But the World will benefit greatly now.  Some engineers better than you et al will solve the loopback problem.
There is no need to find manufacturing partners.  Once the information is out, someone will replicate it. Products will come out and the price will drop rapidly.  The material cost for your existing educational prototype  is less than Hk$5,000.  With Worldwide competition, the selling price is likely to be less than HK$10,000.  All universities and schools will be able to afford that for research and training.  The 5KW version will need more electronics and safety features.  I believe it will sell for less than HK$20,000.  The buyer will not need to pay for electricity as long as the unit functions.  (Estimated time is 10 years.)  You can even help the poorest nations to manufacture them.  All Nations will benefit immediately.
Is this a good Christmas gift to the World?
