chrisC
Quote from: Top Gun on January 02, 2010, 05:39:34 PM
The Better Hong Kong Radio Show
.....  We shall have the US$20,000 course aired free to the World.
Hahaha! You're funny old Tseung. I imagine you couldn't find any fool/s that will give you $20K for conducting some delusional mumbo jumbo Physics course!
Maybe these 'radio' stations can't pull in enough sane people? Are these DJ's mentally challenged too?
cheers
chrisC
markdansie
@Lawrence
"We shall also compare our Tong prototype with those of Steorn, Bedini, Newman, Liang, Wang and the Adams Motor etc."
This is a great comparison as evidence to date none of these work either. Well done. I am sure your credability will sky rocket.
I hope your radio program is in English I could be a regular caller.
Kind Regards
Mark
ltseung888
Flywheel Effect
I was lucky to find the lifting weights have hole that can be made to fit the axle of the Wheel.
Preliminary results indicate that tuning is required.  A 2.5 lb weight produced better result than a 5 lb weight.  We may need to use a larger but ligher flywheel for the best result.  Much more experiment is required.
*** I am more convinced that a factory built version with the known parameters tuned is necessary to properly demonstrate overunity.  Most OU devices followers have mixed results because they could not tune the device.  The inventors cannot help as every home built prototype is different.  I shall not commit the same mistake.
Now that I have the big Wheel in my bedroom, I can do much more experiments.  I shall work with one or more factories to manufacture the Educational Product.  It will be a running OU device from the factory and the buyer may disassemble and reassemble it to learn and improve.
*** We have resolved the question of the best way to measure Input and Output Energy from the Pulsed Current and Voltage.  We shall use the oscilloscope power curve as the standard.  The much cheaper volt and amp meters will be used to show the trend but will not be used as the final result.
*** The remaining discussion is: In the Input waveform, there is the DC and the AC components.  Is it logical to take the AC component out and treat that as Lead-out Energy?
chrisC
Quote from: ltseung888 on January 03, 2010, 09:08:10 AM
....  Is it logical to take the AC component out and treat that as Lead-out Energy?
I think it is more logical for you to take a community course in 'A' level Physics and then if you pass it, proceed to take another course in electro-magnetics and then finally if you also pass that, then take a final course in basic electronics. After passing these classes, you will have enough information to know you've wasted time pumping out 300 plus pages of misguided O.U 'research'! It's plain garbage and nonsense - mostly because you do not understand fundamentals.
Should have volunteered your time helping disadvantaged children in hospitals. Don't you think so, Mr. Tseung?
If you have been able to conclusively shown even 1W OU consistently, many top research institutions will be breaking down your door! Isn't it rather silly to unabashedly announce these $20K courses etc etc and end up 'giving' it away for free? Tens of thousands of people give away fully working large screen tube color TV's for free. Will others accept these free stuff? Apparently not, because they are considered garbage, since the real stuff is the razor thin LCD/LED TVs.
Well, IMO you should just stay a low profile and work quietly until you can prove conclusively this Lee-Tseung crap had merits. Other than that, I'm sure all of us wish you good health, prosperity and especially richly endowed  common sense.
cheers
chrisC
Paul-R
Flywheel Effect
You have a shaft driven by an oscillating source with a flywheel.
This can be a problem for designers of ships' prop shafts and propellors
if the motors behave oddly.
You need to take into account the MECHANICAL resonance of this system,
and drive it under conditions which either minimises or maximises the effect
of the oscillating shaft and flywheel. (I am not sure which).
Paul-R
