0 Members and 105 Guests are viewing this topic.
Mr.Entropy
Quote from: ltseung888 on October 10, 2007, 01:11:17 AM
(3)   If the punch is very slow - to become a push, the String of the Punch bag will move.  The Punch bag system then simulates a Pendulum.  (Pushing a person is very different from punching a person.)
Hope the reasons are clear.
Ok, so you want a gentle force applied through a significant portion of the travel.  How about this:
- a pendulum with a 20g weight and a 20cm string is raised 10cm to a 60 degree angle off vertical and held in place.
- a spring is compressed 3cm, storing 2 mJ of energy, and held against the pendulum weight in such a way that it pushes along the pendulum's direction of travel.
- the pendulum weight is released while other side of the spring is held in place.
- the spring contributes 2 mJ of energy to the pendulum, the pendulum swings down and up to a maximum height of .... what?
CoE says 20cm above the bottom of its travel.  What do you say?
ltseung888
Quote from: shruggedatlas on October 10, 2007, 09:16:39 PM
If a 1/133 of second pulse leads out energy, why does the collision of one pendulum into a still pendulum not qualify as a pulse that leads out energy?  Neither sphere takes any damage.
In Physics, consider the momentum of the two spheres before and after the collision.
Before:
Momentum of Pendulum A = m x maximum velocity
Momentum of Pendulum E = 0
Total net momentum = m x maximum velocity
After:
Momentum of Pendulum A = 0
Momentum of Pendulum E = m x maximum velocity
There is transfer of momentum (and hence energy) from Pendulum A to Pendulum E.  However, there is no external energy input to lead out gravitational energy.
In the 1/133 second Pulse (periodic repeated), we use electromagnetic attraction or repulsion to input external energy to the rotating cylinder.  This additional energy input will lead out both gravitational and electron motion energy.
May be the use of the term Pulse is causing too much confusion.  We can invent a new word - Lee-Tseung Impartation of energy or something.  (This was suggested in the steorn.com forum.)
armagdn03
sorry to but in, but I do believe lifting the first sphere and giving it gravitational potential energy qualifies as adding energy to the system. unless you mean to say that energy must be added at the time of implulse,
I wish I could turn my brain off sometimes, then I could get some sleep.
Hello Mr. Lawrence,
there is a company in Germany: "Power Hybrid"
Their selling objects are based by the inventions from Mr. Manfred Sonntag(Duisburg).
Mr. Sonntag converted a conventional IC-car to an hybrid-car,
at first this seems not special,
but the electric-motor as electric drive,he got from a washing-machine !
+/-  3 KW max.,for a washing-machine-motor,do you agree ?
The experimental REVA NGX showed an electricity consumption of 24 KWH for 200 KM,
less 6 KWH power recuperation,
this means 18 KWH for 200 KM range or 9 KWH for the 100 KM range !
Why do you think that your example of the 8 KWH/100 KM ,Mr. Chao Ching San`s car, is so special ?
KG weight of the car, max. speed - extraordinary ?
Sincerely
              de Lan?a
hansvonlieven
G'day Lawrence,
What gives with these idiotic power point presentations that many cannot read. Post what you have to say in such a way that people with less resources than you can understand what you are saying.
Or, are you afraid to publish your ideas like everyone else??
Hans von Lieven
