Good morning Hans von Lieven,
your Peugeot 407 numbers are refering only a disk modification:
www.espa-system.de/echo.asp
this is not an hybrid-equipment !
Parallel or seriell hybrid ?
http://www.swr.de/rasthaus/archiv/2006/07/29/print3.html
" Manfred Sonntag, Hybrid Erfinder:
..... Tricks auf Lager:
1. ........................ ."   !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!, only the electro-motor as drive !
So,only, the washing-machine-motor as max. power  need reference !
Sincerely
              de Lan?a
hansvonlieven
G'day Lanca,
It says in the article about the car:
Manfred Sonntags Fiesta hat gleich vier Tricks auf Lager:
Manfred Sonntag's Fiesta has four tricks up its sleeve.
1. Der Fiesta kann - sofern die Extra-Batterie im Kofferraum voll ist - ausschlie?lich mit Hilfe des Miele-Motors anfahren, ohne Sprit zu verbrauchen.
1.  The Fiesta can - as long as the extra battery in the boot is fully charged - start on the Miele Motor (Washing machine motor) alone without using any petrol.
2. Der Elektromotor unterst?tzt beim Beschleunigen den Benziner, was auch wieder Sprit spart.
2. The electric motor aids during accelleration the petrol motor, which also saves petrol.
3. Bei jedem Bremsvorgang wird die Extra-Batterie von einem Dynamo geladen.
3. Each application of the brakes charges the extra batteries via a generator.
4. W?hrend der Fahrt kann Manfred Sonntag auf Autogasbetrieb umschalten. Bei Kosten von nur 54 Cent pro Liter Autogas f?hrt er f?r weniger als 3 Euro 100 Kilometer weit.
4. During the journey Manfred Sonntag can switch to LPG. At a cost of only 54 cents per liter of LPG he drives on less than 3 Euro per 100 km.
My comments:
There is NO new technology here, just a clever arrangement of a petrol motor and an electric auxiliary. Every driver knows that starting a motor car and rapid acceleration uses dis-proportionally more petrol than cruising. By having the electric motor step in at those times considerable savings can be made in the petrol consumption. No magic tricks, no energy from nowhere just plain old clever arrangement of existing technology. The battery is recharged using some of the otherwise wasted energy when the brakes are applied. The car at no time drives on the electric motor alone.
Btw. anfahren in this context means start, and not drive. I have left the German text intact to show that I have not taken any liberty with the translation.
Hans von Lieven
No, I am not writing about a new technology !
And the article describes " start and drive", but with 1 battery as electricity source,
also only a very short range is possible , included  the recharging/lost recuperation !
Better reference:
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=DE4128297&F=0
description: page 1,line 52 to page 2,line 12 !
My intention/proposal is to know :  the real  KWH/100 KM consume, with convenient conditions ,
car weight/seats and speed related!
www.loremo.com  : there is a electricity consume estimation of 2 KWH/100 KM ,(FORUM,e-Loremo)
another example: www.mcn.org/a/omni/ElectriliteM2.htm   "ELECTILITE"
S
  dL
ltseung888
Now I would like to comment on the controversial subject of why many Over Unity Developers failed despite years of hard work. Let me start with Joseph Newman.
(1)   Joseph Newman found that rotating a magnet inside a coil seemed to produce extra energy.  The same Coil could be used as Drive Coil and Pickup Coil.  The Pickup Coil could recharge dead batteries.
(2)   Joseph Newman demonstrated that he could drive a heavy vehicle from batteries recharged by his motor.  The batteries did not get depleted.  He concluded that he achieved over unity.
(3)   The tests by external experts were the simple checking of Output Power against Input Power.  When External Load was increased, the rotational speed of the Newman Motor would decrease.  This decrease would cause a drop in Output Power generated.  Without the program to adjust the Output Power to External Load, the Newman Motor would fail such conventional tests.
Thus from the standpoint of the Lee-Tseung Theory, the Newman Motor can be improved as follows:
(1)   Newman Motor is just a pulsed (periodic repeated) rotation in a magnetic field with axle in the horizontal direction.  Thus both gravitational and electron motion (magnetic) energy can be Lead Out.
(2)   The Lead Out energy was fed back via the Pickup function of the Coil to recharge the batteries and more.  CoE was never violated.
(3)   For the Newman Motor to become a useful electricity generator, it must be able to adjust its Output Power according to External Load.  One simple way is to change the current to the Coil to keep the magnets rotating at approximately the same speed.
(4)   Once the mechanism in (3) is added, the Newman Motor can pass the conventional tests as an Electricity Generator.
(5)   The better way is to have multiple Drive and Pickup Coils for greater range and control ? the ?225HP Pulse Motor?.
*** Edited to add:
Almost all the known Magnetic Rotational Devices can be improved with the above recommendation.  It should now be clear to all testers that treating the invention as a black box and measuring the Output Power to Input Power would fail to give the invention justice.
Thank you to Ash et al for doing the Chas Campbell tests.  I realized the above only after carefully studying and re-studying the reports and videos.  The fishing definitely helped.
Lawrence Tseung
Knowing the Lee-Tseung theory thoroughly Leads Out easy improvement for the Newman and other magnetic rotation Motors.
ltseung888
Comments from one of the top research institutes in China.
I shall present their comments in Chinese first.  Ms. Forever Yuen or some of you may translate it into English later.  The quick summary is that they believed in the validity of the Lee-Tseung theory.  They would like to work with Lee-Tseung and other interested parties to benefit the World.
1.   Ã¤Â¹â,,¢Ã¦â€"¹å¾ž?打秋åÆ'的奧秘?éâ€"‹å§‹ï¼Å'深入淺出åÅ"°è¬›è§£äº†?宇å®â,,¢Ã¦â€"°èÆ'½æº?çš„çâ,,¢Â¼Ã¥Â±â€¢Ã¥â€™Å'多樣æâ,¬Â§Ã¯Â¼â€ºÃ¥Å"°çÆ'引力èÆ'½å‹•力機å’Å'çâ,,¢Â¼Ã©â€ºÂ»Ã¦Â©Å¸Ã§Å¡â€žÃ¥Å½Å¸Ã§Ââ€ Ã£â,¬ÂÃ¥Â¯Â¦Ã©Â©â€"證明å’Å'計ç®â€"æâ€"¹ç¨‹å¼ï¼Å'獲åâ€"Ã¥Å"°çÆ'引力場èÆ'½é‡å’Å'磁場èÆ'½é‡çš„æâ€"¹æ³•ï¼Å'éâ,¬Å¡Ã©ÂÅ½Ã§Ââ€ Ã¨Â«â€"分析åÅ"‹å…§å¤â€"çâ,,¢Â¼Ã¦ËœÅ½Ã¥Â°Ë†Ã¥Ë†Â©Ã¯Â¼Å'證明李ãâ,¬ÂÃ¨â€Â£Ã¥â€¦Ë†Ã§â€Å¸Ã§Å¡â€žÃ¥Å¸ÂºÃ§Â¤Å½Ã§Ââ€ Ã¨Â«â€"研究具æÅ"‰ç„¡å¯çˆ­è¾¯çš„示範證明å’Å'可靠依據ãâ,¬â€š
       Ã¤Â¹â,,¢Ã¦â€"¹è¡¨ç¤ºå°‡å”助甲æâ€"¹å…¨é¢çž­è§£åÅ"‹å…§å¤â€"?宇å®â,,¢Ã¦â€"°èÆ'½æº?的研製éâ€"‹çâ,,¢Â¼Ã¦Æ'…况ï¼Å'提供?宇å®â,,¢Ã¦â€"°èÆ'½æº?相éâ€"Å"æÆ'…報資æâ€"â,,¢Ã¯Â¼Å'以便甲æâ€"¹æ·±å…¥çž­è§£?宇å®â,,¢Ã¦â€"°èÆ'½æº?æÆ'…况ãâ,¬â€š
2.   Ã§â€Â²Ã¦â€"¹èªçˆ²ï¼šæŽãâ,¬ÂÃ¨â€Â£Ã¥â€¦Ë†Ã§â€Å¸Ã§Å¡â€ž?宇å®â,,¢Ã¦â€"°èÆ'½æº?? 基礎理è«â€"研究ï¼Å'爲人類大規模利用宇å®â,,¢Ã¦â€"°èÆ'½æºå¥ å®šäº†ç§‘å­¸ãâ,¬ÂÃ¥Â â€¦Ã¥Â¯Â¦Ã§Å¡â€žÃ§Ââ€ Ã¨Â«â€"基礎ï¼Å'將徹底爲人類解决èÆ'½æºç·Šç¼ºãâ,¬ÂÃ§â€™Â°Ã¥Â¢Æ'污染嚴重的重大難é¡Å'ãâ,¬ÂÃ¥Â¯Â¦Ã§ÂÂ¾Ã¤ÂºÂºÃ©Â¡Å¾Ã¥Â¤Å¡Ã¥Â¹Â´Ã¤Â¾â€ Ã¥Â°â€¹Ã¦Â±â€šÃ§Å¡â€žÃ¯Â¼Å'èâ,¬Å'且是åâ€"之不盡ãâ,¬ÂÃ§â€Â¨Ã¤Â¹â€¹Ã¤Â¸ÂÃ§Â«Â­Ã£â,¬ÂÃ¥Â»â€°Ã¥Æ'¹ç’°ä¿çš„æâ€"°èÆ'½æºç†æÆ'³ãâ,¬â€šÃ©â,¬â,,¢Ã¦ËœÂ¯Ã¤Â¸â,¬Ã©Â â€¦Ã¤Â¸â€"ç´â,¬Ã¦â,¬Â§Ã§Å¡â€žÃ¥Â¤Â§Ã§â,,¢Â¼Ã§ÂÂ¾Ã¯Â¼Å'是驚天動åÅ"°çš„偉大çâ,,¢Â¼Ã¦ËœÅ½Ã¥â€°ÂµÃ¦â€"°ãâ,¬â€šÃ¥Å"¨21æâ€"°ä¸â€"ç´â,¬Ã¨Â£ÂÃ¯Â¼Å'éâ,¬â,,¢Ã§Â¨Â®Ã¥â€¦ÂÃ¨Â²Â»Ã§â€™Â°Ã¤Â¿ÂÃ§Å¡â€ž?宇å®â,,¢Ã¦â€"°èÆ'½æº?必將全面åâ€"代現代人類使用的ãâ,¬ÂÃ¦Å"‰æç’°ä¿çš„?Ã¥Å'â€"石ç‡Æ'æâ€"â,,¢Ã¨Æ'½æº?ãâ,¬â€šÃ©â,¬â,,¢Ã¥Â Â´Ã¦â€"°ä¸â€"ç´â,¬Ã§Å¡â€žÃ¨Æ'½æºé©å‘½å¿…å°‡æÅ"Æ'Ã¥Å"¨å„åâ,¬â€¹Ã©Â ËœÃ¥Å¸Å¸Ã¥Â¼â€¢Ã§â,,¢Â¼Ã¤Â¸â,¬Ã¥Â Â´Ã¦â€"°çš„æŠâ,¬Ã¨Â¡â€œÃ©ÂÂ©Ã¥â€˜Â½Ã¯Â¼Å'從èâ,¬Å'改變人類現æÅ"‰çš„生存模式ï¼Å'ä¿Æ'使人類éâ,¬Â²Ã¥â€¦Â¥Ã¥â,¬â€¹Ã¥â€¦Â¨Ã¦â€"°çš„現代åÅ'â€"æâ,,¢â€šÃ¤Â»Â£Ã£â,¬â€šÃ©Â¡ËœÃ¨Ë†â€¡Ã¤Â¹â,,¢Ã¦â€"¹é•·æÅ"Ÿå¯†åˆ‡åˆä½Å"ãâ,¬â€šÃ§Ë†Â²?宇å®â,,¢Ã¦â€"°èÆ'½æº?的推廣應用産業åÅ'â€"ãâ,¬ÂÃ¥â€¦Â¨Ã§ÂÆ'Ã¥Å'â€"ä½Å"出貢獻ãâ,¬â€š
3. ?宇å®â,,¢Ã¦â€"°èÆ'½æº?的研究ãâ,¬ÂÃ©â€"‹çâ,,¢Â¼Ã¦ËœÂ¯Ã¥â,¬â€¹Ã©ÂÅ¾Ã¥Â¸Â¸Ã©Â¾ÂÃ¥Â¤Â§Ã§Å¡â€žÃ§Â³Â»Ã§ÂµÂ±Ã¥Â·Â¥Ã§Â¨â€¹Ã£â,¬â€šÃ¥Â¿â€¦Ã©Â Ë†Ã¥Å"˜çµ?宇å®â,,¢Ã¦â€"°èÆ'½æº?çâ,,¢Â¼Ã¦ËœÅ½Ã¨â,¬â€¦Ã¤Â¸â,¬Ã¨ÂµÂ·Ã¦â€Â»Ã¥â€¦â€¹Ã¥Â¯Â¦Ã§â€Â¨Ã¥Å'â€"ãâ,¬ÂÃ§â€Â£Ã¦Â¥Â­Ã¥Å'â€"的難é¡Å';必須運用現代研究ãâ,¬ÂÃ¨Â¨Â­Ã¨Â¨Ë†Ã¦â€°â€¹Ã¦Â®Âµ(Ã¥Å'…括現代試é©â€"ãâ,¬ÂÃ¨Â£Â½Ã©â,¬Â Ã£â,¬ÂÃ¦ÂªÂ¢Ã¦Â¸Â¬Ã¦Å â,¬Ã¨Â¡â€œ)對應用設計做大量細緻ãâ,¬ÂÃ¨â€°Â±Ã¨â€¹Â¦Ã§Å¡â€žÃ§Â â€Ã§Â©Â¶Ã¥Â·Â¥Ã¤Â½Å"ãâ,¬â€šÃ¥Â¾Å¾Ã¦Å"‰è¼Æ'好基礎的産品éâ€"‹å§‹ï¼Å'獲å¾â€"應用突破ï¼Å'實現産業åÅ'â€"ãâ,¬â€šÃ§Â¸Â½Ã§ÂµÂÃ¨Â¨Â­Ã¨Â¨Ë†Ã¨Â¦ÂÃ¥Â¾â€¹Ã¥â€™Å'製éâ,¬Â Ã¥Â·Â¥Ã¨â€"è¦ç¯„ï¼Å'ç„¶å¾Å'éâ,¬ÂÃ¦Â­Â¥Ã¦Å½Â¨Ã¥Â»Â£Ã£â,¬â€š
