Forever
The ideal Lee- Tseung Pull as applied to rotational systems
This turns out to be easy. The pull is applied tangentially. The pull is also periodic. So energy is imparted to the rotational system. The rotation would accelerate. Hopefully, the energy drawn out by the external load will decelerate the rotational system. If the two matches, the rotational speed will fluctuate within a narrow range. The timing must be correct to achieve the best result. Thus tuning is necessary.
Gravitational or magnetic energy will be lead out.
The 225hp pulse motor and the Liang IC pulse motor are good examples.
hansvonlieven
Quote from: ltseung888 on July 20, 2007, 05:21:57 AM
Fun with explaining the Milkovic Pendulum and Lever system
Reference on this forum:
http://www.overunity.com/index.php/topic,1763.msg39646.html#msg39646
Tseung: "Now we can use this thread to explain every known Over Unity device published.  The idea is to check whether the Lee-Tseung Lead Out theory is applicable to all of them.  If so, can the Lee-Tseung Theory suggest improvement to the devices."
Lin: "You are ambitious.  Since you will never build an OU device yourself, there is no harm is making constructive suggestions.  I suppose you would start with the Milkovic Pendulum first."
Tseung smiled: "Our PCT patent information starts with the Pendulum.  So it is logical to start with the Pendulum example.  In slides 5-8 of http://www.energyfromair.com/beijing/taiwan2a.htm, we proved that a horizontal pulse force applied to a pendulum could Lead Out gravitational energy.  To be exact, two parts of horizontal Pulse Energy can Lead Out one part of graviational energy.  Thus Milkovic is Leading Out gravitational energy via Pulsing the Pendulum."
Lin: "Does the lever movement contribute anything?"
Tseung: "Yes.  The Lever Movement can be thought of as a vibrational system.  The Movement of the Pendulum Bob shifts the effective balancing weight.  Thus the Milkovic system can be thought of as two systems complementing each other - the pendulum and the up-and-down lever.  Milkovic has not completed the feedback loop."
Lin: "Is the Milkovic system an Over Unity Device?"
Tseung: "The Pendulum with a Pulse Force is already an Over Unity Device.  The vibrating Lever with shifting weight is also an Over Unity Device.  The combined system is thus an Over Unity Device."
Lin: "Can some type of pull back string or spring be used to complete the Milkovic feedback loop?  If so, can it run forever and conclusively demonstrate the Lee-Tseung Lead Out theory?"
Tseung smiled: "Theoretically possible.  I shall let someone better at engineering to shine and do the actual experiment."
Lawrence Tseung
Lee-Tseung Theory Leads Out confirmation that the Milkovic system is Over Unity and could produce a mechanical perpetual motion machine/toy.
Remember this??????
If you think you are talking to anyone but Lawrence, think again. He had so many alter egos in this thread this is just a new one with a picture of a pretty girl thrown in as a sweetener.
Hans von Lieven
Pirate88179
Thanks Hans, I guess I came unglued at thoughts of the sweetner.  I am ok now.  Besides, Hong Kong is a very long drive for me from Kentucky.
amateur
perhaps it will be faster if the lee-tseung pendulum can swing u over..... remember your crash helmet though....  ;D
hansvonlieven
If you still want to go Bill, and if you are really, really nice to old Lawrence, he might pick you up in Winnie Woo's flying saucer and you can have a lovely night out with Forever - on Mars!
Hans von Lieven
