Marco's Dancing Magnets.... doing the 7.8Hz dance
Started by tao, July 21, 2007, 04:59:04 PM
tsakou
ATTENTION! YOU'RE MESSING AROUND WITH YOUR BRAIN WAVES!
http://en.wikipedia.org/wiki/Alpha_waves
Quote from: tao on July 21, 2007, 04:59:04 PM
Hey Marco,
Been meaning to ask you. what type of coil did you use for you KICK coil in the dancing magnets?
Toroidal coil or a normal inductor.
Because, one would THINK that a normal inductor(electromagnet) pointed at the dancing magnets would work best, but yours definitely appears to be a toroidal coil in the video...Add to that the fact that is a toroidal coil setup, the B field should be mostly contained in the toroid. So, what is dancing the magnets if it is a toroidal coil doing the kicking? The uncurled A field?
http://video.google.com/videoplay?docid=5540717206741162529
Below is two images I made, to show the two different coils.
Thanks Marco!!!
Why "ATTENTION!...",
this sphere is included,do you not know about Flanagans "Neurophone" !
The later experiment: the inverse function, the mind-detector,4D !
S
  dL
tsakou
Quote from: lancaIV on July 22, 2007, 05:30:25 PM
this speare is included,do you not know about Flanagans "Neurophone" !
S
  dL
Because the only tool I have is my brain. If it stops working properly, I don't need, neither free energy, neither all that techno stuff. Are you sure that in the long run, all that, don't damage your brain? Has anybody proved that?
tsakou
S
  dL
I also looked at neurophone, and it transmits supersonic signals. It doesn't interfere with the brain wave oscillations that have a frequency of 8-12  Hz. Exposing yourself to input signals at that frequencies are extremely dangerous! Ask a neurologist, if you don't believe me.
Signal to noise,noise to signal:
the neurophone transmit the information as supersonic wave,
but how will this wave received and transduced,neuronal ?
Normally chemical,between the synapses.
The alpha-sphere is during our rehabilitation-phase,also called sleep,
the dream/mind movie-period !
We do not know,actually, the consequences,waves frequency-related.
And each body has his own ,different,acceptance-limits.
Magnets have for example,following the patent publication object,
in the uterus an anti-baby-effect ! Specific magnet frequency ?
Can be also usefull against cancer,if real !
S
  dL
