hydroxy powered motor
Started by Motorcoach1, July 21, 2007, 05:55:58 PM
joe dirt
Hello M.C.
Actually The sparkplugs are the injectors, I couldn,t tell where you wanted them.
  just render a few images and hand draw the changes needed and I will change it.
Appreciated
dirt
Motorcoach1
 up date>Ã,   I chated with the kind folks at EmachineShop.com  so if you go to there web site you can download the free software and use it . There is also an online price list file for shop work. I'm still haveing problems drawing the cam rotor in cad this part is the hardest to do so i'm trying to tackel this one first. I'f you know any real good CAD folks that would help in speeding this part along. I will be publishing the connecting rods soon and the oil pumping system . this is an intrgeral part of the connecting rod and the tolerences are important to it's funtion. Next week I go to the electric motor rebuild place to pick up the 86c frame ends (these are totaly enclosed type motor end frames, used in explosion proof type E motors) and get the shaft and berrings . I have a 50 ton press avalible to me for pressing off the amature and then i'll get the mesurments for the rotor cam , this may very on the shaft size , so when you get the CAD program the shaft size will very to the motor you use and compensate that , eather with the shop or change the specs on the program.
innovation_station
well MIKE
verry nice work
i saw you posted your rotor b4 in the lotr thred a long time ago it has made me wonder what the hell it was but now i know if there is any way i could aid you on this project im all 4 it
great work mike
william
Motorcoach1
Up date >, I have come up with the concoidal push from the rotor pushing the piston rod to the side trying to rotate the rod, this will stablize the rod and stay stright to the cam rotor, I will publish this soon and get some CAD files on this part with the the oil injectors built in the rod guides.  the oil pump was internal but have decided to move this assembely for maintance puropses and easyer to work on in case of failuer. I think you will like this double screw oil pump , easy to rebuild and has a high ware factor ( no friction operation ) it should be able to maitain the 80 lb PSI continous pressure the internal pump that each piston rod has is the high pressure side of the pump asssemebly. Mike   ok Cad guys we need some help here.  Thank you this is a group effort !
Motorcoach1
UP DATE>Ã,  here the drawings on the Piston rod and slide block.Ã,  The bearings are not drawn in yet dew to the type I'm going to use at this time. The oil lines are not posted yet , to feed the slide and piston. if you would like to know please contact me. other than the Cam Rotor This is the second part that needs to be made , you will need 6 of these units. MikeÃ,Â
