Thanks to ALL for your help!!
Patent # GB 763062 1kW Output 6 Million Amp Hour Battery HUGE!!!!
Started by saintsnick, July 24, 2007, 12:10:54 AM
Groundloop
NETIKS
I think this was never patented its only patent aplication do you have date when it was patented????????
A new apparatus for producing an electric current
Application Number: GB19530017167 19530622
Publication Number: 763062 (A)
Application Date: 1953-06-22
Publication Date: 1956-12-05
Assignee: Harold Victor Colman, Ronald William David Seddon Gi
IPCL: G21H 01/00
Bruce_TPU
Here you all are, to help you out.
Here is the Patent in .PDF form.   ;)
Cheers,
Bruce
DOWNLOAD:
NETIKS
1)  cobalt(II) nitrate hexahydrate
2)  cadmium chloride
3)  3Ca (Po3)2 + 10C The formula looks incomplete.
WHAT IS THE THIRD ELEMENT???????
