Electro magnet design software advice?
Started by Honk, July 24, 2007, 09:44:24 AM
Honk
Hi.
As most of you readers know I've been helping Jack to build a controller for his very promising Magnet Motor.
http://jackh.pbwiki.com/
http://www.overunity.com/index.php?topic=2386.0
I have come pretty far in my own design of a Hilden Brand style motor but now I would like to simulate the flux fields
of the electro magnets within the motor. I could of course make test windings but this takes a lot of time.
I wonder if you guys can recommend a good program that can calculate the flux in electro magnets with a silicon steel core?
Once I have the motor and magnets calculations completed I will release my my stuff here at OU forum.
Magnet Power equals Clean Power
Paul-R
You will know of FEMM:
http://femm.foster-miller.net/wiki/HomePage
and I presume that it cannot do it. Why not ask
the boss if he will write up an implementation of
exactly what you need?
http://femm.foster-miller.net/wiki/DavidMeeker
No harm in asking.
Paul.
Honk
I have installed the FEMM software but I find it very difficult to use. Perhaps I'm stupid
but the interface is not very self tutorial. Just to form the desired shape is hard to do.
Isn't there just a simple spreadsheet where I can input the numbers and get the result.
If the input numbers would look somewhat like this it would be nice.
1 ) Square Area of Silicon Steel Core.
2 ) Length of Silicon Steel Core.
3 ) Outer radius of Silicon Steel Core = Inner radius of coil
4 ) Diameter of used wire.
5 ) Number of wire turns.
6 ) Number of wire layers.
7 ) Total wire resistance.
8 ) Output gauss of the electro magnet with steel core.
acp
Hi Honk,
I had the very same experience when I first tried to use FEMM, until I downloaded the tutorial and worked through it, and then everything seemed fairly straight forward. Now I find it very quick to develope new models. Also invaluable is the Lua script facility, which allows to automate incrementing the rotor of a model a few degrees as desired and torque measurements or gif pics saved for every increment, all at lightening quick speed. I would recommend making the effort to learn the Lua scripting.
Albert
Honk
Thanks, where can I download the Lua scripting?
