Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bruce_TPU
@ All
Please download the newest, latest version of the Bob Boyce Toroid System, >.PDF V.1.5
This can now be downloaded from page one of this thread, at the bottom of the last photograph on the build page.
A couple of new chapters, photos and many more of Bob's comments and teaching, can be found in this version, as well as a few other things.  Enjoy!
@ Bob,
Thank you very much for the heads up about the winding.  I am already surpassed where my winding was, and now have the confidence that it is correct, this time.  I have also applied spacers to my two newly wound primaries, as we did to the secondary, which I did not realize was needed, until your post.  So, thank you again!
High regards to all,   ;D
Bruce
Thaelin
MarkSnoswell
@bob @all
Well this is interesting... I have a whole set of resonances in the 1 - 12Hz range!!!
Let me back up here a bit first. This is using the Ferroxcube core I am testing but I think the results are highly relevant to everyone -- so I am posting a prelimenary note here. All these tests are with open ended drives and high impedance loads -- so I am talking about potential resonances and not magnetic or magnetoacoustic resonances. You cant drive any significant load from these resonance modes (in the configuration I am testing).
In addition to the 1.8 MHz resonance I posted on earlier I have a fundamental resonance in the 60 - 90Khz range (it varies depending on exact configuration). I was scanning over the full frequency range with both square and sine wave drive when I stumbled onto the resonances in the VLF range. The VLF drive was stimulating the 80KHz resonant mode -- directly and as complex beats. This amazed me untill I went back to the main resonance in the 80KHz range and plotted it's dependance on drive ampllitude -- the 80KHz resonant frequency is strongly dependant on drive amplitude. (2KHz variation from 300mv - 2400mv PP drive).
I wont give details of the configuration just now as thats not important and I have a lot more testing to do first -- the important thing to note is that with a stong dependance on drive amplitude we have another non linear system... which can be modulated by (or couple to) VLF signals.
It also means that there will be non-linear modulation (hetrodyning) of multiple input freequencies based on amplitude alone.
So: I have now seen a mechanism for both magnetoacoustic and potential non-linear signal modulation.
... which means that the system is a lot more complicated than I would ever have imagined. We have two distinct mechanisms for non-linear signal modulation: E and B potential -- with two or three inputs the potential for feedback hetrodyning means that you could generate/tap into just about any frequency you want.
If that has lost you all then I'll leave you with one further message -- this tends to confirm my idea that you can modulate the output via the static bias. This would be the perfect way to generate power in sync with the mains.
Mark.
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
Grumpy
It all starts with the primary potential, which makes the fields.
This is all I'm working on now - potentials.
        -Frank Edwards
eldarion
Bob,
I have a few more questions for you, if you don't mind ;)
1.) Have you ever observed a cooling effect in the coil or does it always run hot?  I was wondering if the coil may actually be utilizing some thermal energy from the environment...just a shot in the dark.
2.) Is it OK to put a capacitor across each of the primaries when driven in single-ended mode, in order to "force" a resonance at a lower frequency?  Or will this not work with the longitudinal energy?  Just wondering, as I found that the primary coil resonance is very weak with the small capacitance in my test coils.
3.) I noticed that someone deleted the posts on OUPower.com related to the TPU.  I personally found those very helpful as a way to realign my thinking every time I go off on a "conventional electronics" thought path.  Is there any way you might be able to re-post them here?  They also seemed to sum up the basics of the energy converter nicely.
Thank you! :)
Eldarion
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
