Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
eldarion
Hey Bob,
I came across this post in my Internet cache:
QuoteHey there Palic
You may wish to try to source some NTE87 transistors. They are in a TO-3 case style, and are a better choice than the TIP3055 used by J L Naudin.
In the mid 90s I built a successful replication of professor Shinichi Seike's G-strain energy absorber device using three of the NTE87 transistors as a set. I also used a set of three transformers. The outputs of these transformers were rectified and filtered, fed to a load, and back to the input as well. While running, it powered the load, and put a charge into the battery. When the battery was disconnected, the unit went into overunity runaway, quickly burning out both the load, and the transistors. I went through several sets of transistors before I eventually shelved the experiment for a later date. It was interesting to note that the heat sinks on the transistors would frost up every time, just prior to the voltage rise wiping out the transistors. It was as if a peltier effect was taking place in the transistors.
Bob
Is there any way you could post a schematic for that circuit?  It sounds very interesting, and if I leave it hooked up to a battery I could study it and use the knowledge gained to get my controller working better...maybe even get the coil online and running properly... :)
Thanks!
Eldarion
EDIT: I have been going over the attached two schematics, and noticed that Seike is simply using a blocking oscillator on each of the three primary coils.  It looks like this would give a free-running self-resonant three-phase oscillator--i.e. as each oscillator fires, it will trigger the next one in line.  Is this what you built?  It is a concept that Steven Mark had confirmed as correct...
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
Grumpy
Try separating the ground of the secondary from the others so that it's output is by pure induction, and no I do not mean "electromagnetic induction".
It may help for all to view these devices as something that pushes the ambiant potential, which pushes back - harder - similar to what Bob has said.  Kinda goes with some of SM's words too.
        -Frank Edwards
eldarion
Quote from: Grumpy on October 06, 2007, 11:22:49 PM
Grumpy,
I am sorry, but I do not understand.  Right now both the signal generator ground and the secondary coil ground go to Earth ground.  Are you asking me to leave a ground wire floating, and if so, which one?
Also, could you please elaborate on the type of induction (is it electrostatic)?
Thanks!
Eldarion
-- Thomas Paine
Earl
Hi Eldarion,
here is a simplified, generic version of Seike's self-swinging 3-phase WYE oscillator.
Both primary and secondary are in WYE.
The oscillator feedback is at the electrically "cold" end of the primary, in traditional, classical HF radio fashion.
If the gain of the inverting amplifier is high enough, I don't see any reason to use two for each oscillator WYE leg.
See also my recent post at
http://www.overunity.com/index.php/topic,3403.msg52902.html#msg52902
for a self-swinging 4-phase quadrature oscillator.  This type of oscillator does not need any secondary coils for feedback.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Bruce_TPU
@ All
I just want to make a correction, when everyone is discussing their experiment in the future.
The magnetic bias is the only "bias" Bob refers to.
The secondary is referenced as the High Voltage (160 volts) DC Potential.  Not the HV Bias.  I know this because Bob corrected my calling it a HV bias, some time ago.
I also believe that one end of the DC potential is ungrounded and "floating".  This is what Earl mentioned some time ago when we were working on the diagram. Again, Bob, please correct me if this is not correct.
So the ground would be from the ground on the controller to load and positive from the one wire on the secondary.
Some quick thoughts,  ;D
Bruce
