Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
MarkSnoswell
The motors work fine. They are just old technology - the went on to much more interesting things.
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
Earl
Quote from: hartiberlin on May 22, 2008, 01:04:44 AM
Hi Mark,
Why didn?t they publish the motors
some more  ?
Where there still problems ?
Harti,
Many years ago, the inventor was threatened with harm to his family unless he kept quiet.
Governments with oil reserves, such as Mexico, do not want the introduction of FE.  In fact, I know of no government that wishes FE to come into general usage.
You do know about the German government hypnotizing students and a professor because of an experiment with water electrolysis, don't you?
Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
EMdevices
thanks for that link Bruce.
I signed up with INFOPAT and here's the abstract for the first entry.
QuoteLa presente invención se relaciona con un sistema generador o transformador de energía eléctrica que comprende un circuito eléctrico que comprende ocho circuitos: un circuito de senso enlace, un circuito sensor, dos circuitos oscilatorios, dos circuitos amplificadores, un circuito mezclador, y un circuito de senso salida, por medio de los cuales se obtiene una ganancia de energía que es aprovechada por un motor (carga inductiva) logrando de esta manera que el elemento motor consuma hasta un 50 por ciento menos de energía, por lo tanto logrando un ahorro de energía considerable. Además, el sistema generador o transformador de energía eléctrica de la presente se puede acoplar tanto a sistemas de corriente alterna como corriente directa, con las mismas características de operación."
and the translation (with Babelfish)
QuoteThe present invention is related to a generating or transforming system of electrical energy that includes an electrical circuit that includes eight circuits: a circuit of senso connects, a sensorial circuit, two oscillating circuits, two amplifying circuits, a mixer circuit, and a circuit of senso exit, by means of which an energy gain is obtained that is taken advantage of by a motor (inductive load) obtaining this way that the motor element less than consumes until a 50 percent energy, therefore obtaining a saving of considerable energy. In addition, the generating or transforming system of electrical energy of the present can be connected so much to systems of AC voltage like direct current, with the same characteristics of operación."
isn't that interesting..... wow!!     two frequencies and mixers and energy gain, if that's not related to the TPU I don't know what is.
Bruce_TPU
Hi EM,
Great find!  I think that it is very much related.  Are you able to get your hands on the patents?
Perhaps he too is using an electronic pulse delay for amplification effect.  Hmm... it would be interesting if he found a way to do electronically what SM did mechanically.  But it would make all of the sense in the world.
Cheers,
Bruce
MarkSnoswell
Mexican patents are not availble to read. Fred Epps was tracking this down back in January and was goin to buy a copy of the patent -- I must ask him if he ever got a hold of the full patent.
Dr Mark Snoswell.
