Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
tao
Quote from: btentzer on July 29, 2007, 12:31:19 AM
@ Mike
A bright idea.  Though it will read funny on the "build page" when I get it together.  One toilet bowl seal... ;D  I had no idea it was made of Bee's wax!
I have verified it is 100% bee's wax.  I won't ask how you knew that Mike!  LOL   ;D  So we now have a ready, cheap souce at our disposal (no pun intended! Ha!) from any local building supply.
Bruce
I indeed found the wax at Home Depot today, guised as a toilet seal, lol.
May I suggest also though, lol, they have many forms of wax and like materials at Hobby Lobby stores around the US...
Grumpy
Ray Tomes
34560 - Universal Ratio
http://ray.tomes.biz/index.htm
For those who insist that the Schumann Resonance can be harnessed:
http://www.mondovista.com/schuman.html
        -Frank Edwards
Grumpy
Quote from: Bob Boyce on July 27, 2007, 12:27:48 PM
Sorry, thought about that after I had posted. I should have offered the following;
Polar = anomolous electrical / magnetic effects
Parapolar = anomolous heating / cooling effects
Diapolar = anomolous gravitational effects
3 variations of a common thread. Many anomolies observed are results of unbalanced mixes of 2 or more of these. It's just a theory and I really don't care about theory as much as actual hands-on research and experimentation.
Bob
Hello Bob,
In the above orientations, or states, are you referring to the orientations of the fields in the ring?  Just wondering what would could be expected with phase coils with same poles turned inward or wrapped with current primary method but with poles opposing.
You mentioned that the lightening strike entered your hand - was this by chance the palm or some other portion?  I ask this specifically because the palm of the hand is thought to be sensitive to torsion fields.  The lingering field that you spoke of is consistent with many people's experiences with torsion fields.  Dave Lowrance has experimented with coil arrangements that create torsion fields without applied power and others that are very difficult to shut off once active.  Very strange stuff indead.
Do you have any ideas on why the rind does not function when flipped over or rotating CW?  This is obviously and indication of where the energy comes from - (as in - not from the ground beneath you) - but the source could be Earth or something outside it.  Aside from the gravitational field, the Earth has a torsion field as do many other celestial entities and they appear to effect each other.
Have you ever placed two rings side-by-side when operating?
Have you ever placed a ring inside another ring - perhaps with the inner ring rotating CW and the outer ring rotating CCW and collection in the middle between the two?
Sorry about all the questions - bored at work and can't work on the ring here.
Thanks Much,
Grumpy
EDIT:
surplus source for electrical winding tape:
http://www.surplussales.com/RF/RFTeflon-Mylar.html
The yellow, non-stretchy, thin stuff is polyester (Mylar is a brand name - of 3M - I think) - look for the yellow roll on the page.
These prices are a little cheaper than standard pricing.
        -Frank Edwards
HumblePie
Hey Y'all,
You all better read everything twice if you are like me.  Make time.
Humble
Bob Boyce
Quote from: Grumpy on July 30, 2007, 03:44:10 PM
Bob
Hello Bob,
Thanks Much,
Grumpy
EDIT:
As far as I can tell, the states have nothing to do with the orientation of the windings. I do not have these other anomolous affects mapped out to a specific interference (standing wave) pattern. Some resonance points will give a different set of anomolies than others, and the frequencies at which these occur will vary based on the resonances of your particular core and windings.
The lightning entered the palm of my right hand with no entry wound. My right hand was resting on the shelf of a metal book rack that was next to the wall where the lightning entered the room. The exit wound was on the outside of my right ankle where it jumped from there to the telephone 3 feet away. I was laying in bed at the time.
I had not tried turning it on its side or upside down when it was running. I do not like going near strong EM fields for health reasons. There are some subtle measurement differences that can be observed when testing at low power when wound and driven in one direction vs the other. For example, when wound  and driven correctly, far field radiated EMF as read with an EMF meter seems to vanish when a load is connected.
I have not messed around with multiple rings. In all the testing I have done, closed rings of conductive material just seems to introduce eddy current losses and the resultant heat from those eddy current losses. I have always strived to obtain the best results I can with the least amount of power input.
Bob
