Longitudinal wave research
Started by MarkSnoswell, July 28, 2007, 06:31:29 AM
tao
Quote from: Jdo300 on August 08, 2007, 06:43:04 PM
Hi All,
This issue of the receiver being grounded has always bugged me. I have always wanted to build a Tesla wireless power transmitter just to play with it. I was especially inspired by the one that Marco posted on the forum a while back. I'm very curious to see what would happen if you were to have more than one receiver pulling power from the transmitter. Would the transmitter 'perceive' the load from the receivers? If not, then one could conceivably have power multiplication simply by adding more receivers for the same source. Or, you could put the transmitter and the receiver together as one and use feedback to increase the gain of the system.
God Bless,
Jason O
I have always thought about this also Jason, exactly what you wrote here. What would happen ;).
Bruce_TPU
Here is a cool link, making today's news, using Tesla's Longitudinal waves in a wireless transfer of electricity and an artistic approach:
Hmm... forteantimes wants membership...
Go to www.coasttocoastam.com scroll down to "New Tesla-inspired light bulb".  Click it, and you can get there without a membership
http://forteantimes.com/blogs/editorial-blogs/news/940653/new-teslainspired-light-bulb.thtml
Grumpy
http://montalk.net/notes/tesla-wireless-technology
http://www.tfcbooks.com/tesla/1919-05-00.htm
"Divergence of the vector potential" is something that Stephan Marinov was emphatic about and he built his MAGVID device to produced this effect - using a RMF in combination with a polodial magnetic field (Z-axis of toroid).
How very quaint indeed...
        -Frank Edwards
tao
Quote from: Grumpy on August 10, 2007, 12:18:26 AM
That first link is amazing...
Jason, looks like he might have answered your question about multiple receivers:
"In case you missed it, there is a critical implication here. The transmitter does not lose energy by generating longitudinal waves, yet the receiver responds to those waves and generates a measurable current. This means that if the transmitter uses a million watts, and the receiver outputs the same, ten more receivers can each output a million watts without putting additional load on the transmitter. Where does the extra energy come from?
Well, there is something very special about an oscillating divergence in the vector potential, namely that it creates an oscillating time field that extracts energy from the flow of time itself. If you have ever wanted to know the secrets of free energy, this is definitely one of them. Under ideal conditions, the transmitter sends an information signal that nudges the receiver into extracting free energy from the time stream. Some would call it extracting the zero point energy, same thing if viewed from the quantum mechanical perspective instead of general relativistic. Due to the first equation showing the relation between divergence and charge density, charges vibrating in a compressive / expansive manner automatically extract free energy that adds to the amplitude of their oscillation.
That the transmitter and receiver electrically oscillate at resonance is how one can dial specifically into the other, and that their mode of oscillation involves radial electron compression makes the entire process assisted by free energy."
Looks like this is what Steven Mark was talking about when he mentioned have multiple electron flows in one wire at the same time:
"Tesla?s system employed was a collective compression and expansion of electrons. That follows from the coupling between divergent vector potentials and electron density. It is unique because a wire carrying such a ?current? will have both ends pulling or expelling electrons at the same time."
Jdo300
WOW Tao! Thanks Grumpy for the great link!!!
I am about to take a road trip today so I printed out the links and will be reading them on the way down. Sooo It looks like the Tesla MT really is the secret to the TPU after all? I only have one question left now. How could we build a transmitter and reciever that don't need to be grounded??? If I could figure this out, I'd be working on one of these right now!
The only plausible thing I can think of is to ground the receiver to a point on the receiver coil where there is a node... Kinda like CB antennas can be grounded to themselves even though their not actually grounded. Not sure if this could apply in this case though. What do you all think? Have you seen any documents by Tesla or other people that address this? I remember Steven talking about "finding the circuit potential" maybe this is what he was referring to?
God Bless,
Jason O
