Experimenting with Double Helix HHO
Started by IronHead, July 28, 2007, 01:17:27 PM
IronHead
I shaped it quick like by hand 3"x16"
The epoxy plumbers putty was temp to hold the shape till I got to this point.
If you need to shield an area from GOOP then this Blue Painters tape works very well as the GOOP does not stick to it.
JamesThomas
Yes, WOW! That seems like some excellent production for 8 amps. Interesting how the flat positive and negative surfaces are so distant from each other, yet there seems to be uniform active production on all sides.
How about a smaller double helix down the center of a bigger one, so that these two could fit within a 4" or 5" tube?
Look forward to seeing and learning more on this design.
j
We are not what we believe ourselves to be.
keithturtle
Good stuff, IronHead... now I know what I can do with all them 1" 26 ga strips I got.
Keep it safe.
Turtle
Soli Deo Gloria
JamesThomas
@IronHead,
Your s.s. strips look pretty shiny. Did you do any of the recommended crosshatch sanding on them?
j
IronHead
once fitted into the pipe housing I will hone sand internally .
