Experimenting with Double Helix HHO
Started by IronHead, July 28, 2007, 01:17:27 PM
ZeroFossilFuel
It sits in a charged state for a good long time. I think days. So electrolyte polarization is not the most likely answer. Also, regarding efficiency, conventional electrolysis is certainly not overunity. Even so, it is much closer to it than say an Internal Combustion Engine. When applied to the ICE, total system efficiency can be increased, all with conventional application of technology.
Ultimately, what we're after here is the key to unlock the secret to water splitting efficiency - Very low power in to get very large amounts of usable energy out. We believe it's possible. That is our goal.
Zero Fossil Fuel
My public PGP key. Please help support my work. Donate by PayPal
Super God
Exactly, water adds energy to the system so we probably can already run ICEs on electrolysis.  I mean, it doesn't take THAT muh gas to run an engine.
>9000
helmut
Quote from: europeanhillbilly on August 09, 2007, 08:06:22 AM
Quote from: ZeroFossilFuel on August 09, 2007, 07:49:00 AM
You know what really intrigues me? How two plates of the exact same material can become molecularly polarized in a solution of electrolyte by applying a voltage so that, once voltage is removed, a residual charge remains as if you had dissimilar metals in solution.
True, the same is happening on my helix design.
Now, this may sound like a real newbie question, but does this happen with other cell designs too? I guess it does?
Hi
Not in copmpetition to the duble Helix but As an usefull idea led me introduce a link to
a company.This kind op wire can be find easy all over the world.They have it with sharp edges ans made from Stainless steel too. By the way:my english is very lousy and i hope ,that nobody care .
Type:S-Draht-Rollen, Natodraht - Typ SZ
Link:http://www.rotec-berlin.de/r_frames.htm?zaun/drahtgitter/natodraht.html
helmut
dlwammo
@helmut
That's where I'm heading with double-helix #3.  I'm waiting for some stainless orthodontic wire. Square with sharp edges if anyone whose had those in their mouth can attest to...
Going to wind a pair up like a bifilar coil as close as possible using a lexan holder so that the coil will also be as flat as well.  I'm hoping that between the front side and back side parallel wires I can also get some interaction between the front and back with each other.  Next step will probably be to twist each wire individually, and then wrap them the same way as before.   Should be interesting.
Dan
Don't mess with old farts... age and treachery will always overcome youth and skill!
