Weekly Builders Update Diary
Started by Bruce_TPU, July 29, 2007, 03:39:16 PM
poynt99
I think it might be of some benefit to keep one private thread for the TPU work IMHO.
.99
Bruce_TPU
Quote from: poynt99 on November 08, 2010, 11:56:36 AM
.99
I would agree with Poynt99.  One never knows when it may come in handy again.  Also, Bob Boyce has not yet given me the go ahead to release his information, yet.  I have his entire .pdf that I have build.
Also, Jason Owens, some time ago, flew to Florida and tested his controller on Bob's toroid and said that it produced OU for sure.  The only time he has seen that with his own eyes.  For what it is worth.
Bruce
EMdevices
Oh it will come in handy,  that's a promise......
BEP
Please keep it private.
When the times comes to request validation, keep the animals in their other cage until the work is presentable.
