Bill Muller has shown it too !
Started by hartiberlin, May 29, 2005, 06:59:35 AM
FreeEnergy
just have it setup on a horizontal level. no ring magnet needed for this setup, but yes a ring magnet should be better.
i should be getting some metal balls tomorrow!
hartiberlin
I just got my steel balls in today.
Stay tuned.
Regards, Stefan.
Light
Quote from: hartiberlin on June 03, 2005, 04:56:13 AM
If you click reply, then you get a new message window and underneath you have
an ATTACHMENT line, where you can search your harddisk and
attach a picture to the posting.
Hope this helps.
Thanks.
Thanks, I'll try. I simply used quick reply.
hartiberlin
With Quick Reply there is no attachment window.
You must use the normal REPLY button.
Hoep thsi helps.
Regards, Stefan.
hartiberlin
I just tried a first setup with my new steelballs and the plastic hose and the magnets.
The problem is, that my hose has an inner diameter of 16 mm and I only
have 10 mm and 15 mm steelballs.
Now the 15 mm balls are just too wide, they begin to stick to the inner
walls at some spots and this does not work.
The 10 mm balls are again too small for the 16 mm
hose, cause if I put a magnet outside some of them aligns in zick-zack
curves, like  .`.?.?.?.?.?.?.
sothis is happening cause the hose diameter is too big versus the 10 mm ball
diameter.
Also the hose has pretty big friction onto the balls.
Also I have seen, that it would need steel cores sideways to attract the balls better to the
magnet and this must be done like something simular like multiple SMOT ramps in a row
around the hose circle.
So it must be a very precise setup to get this thing to work.
So it will take some time and the right hoses and balls and the right
metal cores and magnets to get something to work.
Not so easy and all must be fixed well to a stable table.
Regards, Stefan.
