Gyro-Magnetic Generator
Started by Nebularnemesis, August 11, 2007, 12:40:29 AM
Nebularnemesis
Hello, I happen to stumble on this website by accident...   I have been interested in building a power unit for atleast 5 years now but before I go into it I would like to say that we already have the technology to harness energy from the Earth's magnetic field using a satelite with a tether that is crossing the magnetic field at 15,000 miles per hour and generates an enormous amount of energy and then converts it to a transmission wave that beams down to a stationary power unit on Earth which in turn reconverts the wave back into electricity.   And since it is very easy to keep a satelite in a stationary position above the Earth there is no problem with it not lining up with the station.   I'm just confused why we don't use the technology we have, because it's the safest form of energy we could ever have and it's not that complicated!
Anyways, I hoping anyone who is great at building things could help me with a proto type of a different kind of power device.(I don't want any money, I just wanna see it work, so the more heads the better on this project!)   Mine requires a Cylintrical drum sitting upright(I'll do my best to describe it)   Inside the drum resting at ~22.5% angle is a wheel that spins on a verticle axis.   This wheel should be able to roll around along the inner drum wall.   Remember the wheel however is at ~22.5% angle to the wall.   Now exactly perpendicular to the wheel is another wheel(substantially smaller as to not touch the wall of the drum) that travels the outer rim of the larger wheel but who's axis is directly connected to the perpendicular axis of the large wheel's axis.   This wheel will naturally swing to the lowest point of the larger wheel due to gravity when observed without any other forces but gravity.   Now hopefully your all still with me and I haven't lost anyone.   The material that the drum and the larger wheel are made of are of any non conductive nature, whether it be wood, fiberglass, plastic, whatever.   ok, now we line the inner wall of the drum with a single band of magnetic material that will have it's polarization going all the same direction around the drum.   The little wheel will be of magnetic material itself, but polarized to push away from the walls of the drum.   Now picture this...   The little wheel will stay away from the walls and basicly off set the balance of the larger wheel so that it starts to travel in one direction.   Both wheels will continue to pick up speed as they continue to rotate around the drum until either friction or the force that governs gyroscopes(whichs I can't remember what that force is called)causes it to reach a terminal velocity.   Now If someone can build this I would love to do some measurements so I can make the ajustments needed to allow it to not only spin fast enough but also create the right weight for the wheels to create enough torque on the larger wheel axis in order to turn a generator.   If this can work, I believe we will all be able to have a shed sized power unit in our back yards to power our house, and for cities they could construct larger units to power other structures, even maybe roads like they do with bumper cars.   Anyone with some input or problems with this design let me know on here.   So far all the small experiments I've done over the past 3 years have been successful, just need a larger unit and strong mangentic material(which is not cheap by the way).
If someone knows the name of the gyroscopic force I'm talking about please post it here for reference.   An example on what this force is(this is a fun trick), take a bicycle wheel and hold it upright like it would be on a bicycle.   Put one end of the axis of the wheel on a finger and with the other hand spin the wheel as fast as you can.   The wheel will remain upright as if by magic and it will exert a small force causing you to turn in place as it rapidly rotates.   It's really cool and fun(I guess if your a nerd like me...lol)
I've added a drawing submitted by Wattsup and I will attempt a drawing myself to better display the project.   For now, this drawing will do with a minor change.   The axis on the large wheel needs to remain perpendicular to each other or in other words the axis of the larger wheel is also slanting.   Overall that was a great dipiction of what I was explaining.   Much debate is required for this project, and anyone able to construct it as a prototype would be my hero!
Nebularnemesis
This is a freehand attempt of drawing the entire device.   The drawing is horrible, I know, but like I said, I'm no artist or CAD expert.   Whoever is a CAD expert can clean it up.   But I figured I'd get it out there atleast for now.    ;D
dlwammo
The bicycle wheel....
Check this out, Mr. G knows what your talking about.
http://youtube.com/watch?v=P014jvaB3ic
Good Luck!
Don't mess with old farts... age and treachery will always overcome youth and skill!
Nebularnemesis
Thank you, that video was a perfect example of what I was taliking about and he did mention the terms I was asking for which are Angular Momentum and Gyroscopic inertia.   They both play a large part in the success of the device and also restrict the device as well... kind of a double wammy.   But that is why I need a proto type so I can take measurements.   Thanks again for that excellent link!
FreeEnergy
