The truth about "overunity".
Started by Navi-gator, August 11, 2007, 09:10:45 AM
Navi-gator
No device can be built, to run any given speed, even if the input is less than the output and be called an over unity device.  The speed it was designed to run at, is the unity of that device.  If this happens, the output being greater than the input, and no so called governing mechanics were installed to keep it at a given speed, the device would pick up speed, constantly picking up speed, and the unity of that certain device, would be the point that the speed of the mechanics would explode the device, once again, never reaching over unity, but only unity.
Now, if a governor of sorts, say an Electrical Generator that is designed to run at a given speed, no matter how much energy or power is delivered to it, was installed, then the unity of that device would be the speed the electrical generator ran at and the work it accomplished, as the unity it reached.
The amount of electricity each generator develops, is the unity of that specific Power Plant.
A device that simply runs is a useless device, and if it is put to work, the unity is the work it performs.
This is the reason no over unity device has ever been discovered, even though quite a few say they have one.  What they have is a toy, using some free energy like magnetism, and because they can get it to run, they call this running, over unity.  The problem is, once they attach an electrical generator or some kind of work, as the device cannot develope more magnetism, unless electricity is involved, and this requires a generator of sorts, they can never go over that which they develop as the output, in the form of the work of the generator developing more magnetism.
pese
This we have learned in school ...
tks.
this tread cant help to find.
You must look other "sources" than the conventionals...
Pese
Navi-gator
Quote from: pese on August 11, 2007, 03:20:00 PM
This we have learned in sholl ...
tks.
You must look oter "sources" like conventioals...
Pese
sholl?..tks?... this whole post ???
Navi-gator
Exactly what is the ?unity?,  ?that the output? is ?over?unity?, that the ?over? is talking about?
Is the unity, energy?
Is the unity, power?
Is the unity, work?
Is their a  difference between overunity and over efficiency?
This is a fairly new term, how do you define it?
HopeForHumanity
You arn't thinking on the right level, you are generalizing that overunity meens exceeded mechanical strength. Overunity is the ability for something to generate cop > 1. If you generated it all out of electricity, you would not have a mechanical problem, because their would be no set mechanical strength. 100% efficient meens unity. You say that everything is 100% effecient? No, they are usualy far behind, you are thinking about mechanical exersion being unity because the FORCES are exerting mechanical pressure on the system, not the ENERGY. It takes a bit of thinking to seperate mechanical effeciency from energy effeciency, think about wave types, if you pull something you are exerting a force on the object. If you are spinning something you are exerting a smaller force on the object, and the amount of energy produced would be the same as the energy it took to pull, therefor decreased mechanical pressure and increased energy effeciency. Simmiliar to how mechanics is length, and energy is width, one can far exceed the other. Say the width is 1000watts, and the mechanical strength is 1000pounds, the input was only 10watts, and the mechanical pressure was only 10pounds. Help clear it up? ???
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
