Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
capacitor70
Output is more than my cell, In video cell is conditioned for eight days.
http://uk.youtube.com/watch?v=47o3YqfUaBg
I don't have CRO to see wave forms  :(
Chris31
@xbox
Very impressive gas production you got there.
Does the bifilar coil really make any difference?
When I tied the bifilar on my 2 round plate SS cell, I didnt notice much difference. On top of that, on the Dave Lawtons 555 PWM circuit the duty cycle changes when the frequency is changed, I find it difficult to mess around with the setting while keeping an eye on the gas production and the current drawn.
I got busy with the plasma spark at the moment, but what I think I need is a good solid gated square wave generator, the duty cycle can be fixed, regardless of the frequency setting.
insane4evr
Hi xbox,
Can you post SS tube dimensions. Inner tube OD, outer tube ID, and length.
Did you get brown muck in the water after a while?
Thank you very much.
Edit: Deleted bifilar core info request, got the answer in earlier post.
xbox hacker
Quote from: insane4evr on August 30, 2008, 08:22:15 AM
Hi xbox,
OK...the outter tube is:
OD: 0.438
6" long
the Inner tube is:
OD: 0.311
7" long
Both are 304SS, yes they do have a welded seam down the center.I went with these tubes to start with because they are CHEAP!! I figured, a car maker makes a scale model befor they build a real car....so thats kinda what i did.  ;D
insane4evr
Hi xbox,
Thanks for the info. I notice that you are using a PC power supply in your setup. Here is a simple power cycler I am using. It will not do the various preset on/off times in the DL document. It has a fixed on time and off time you can change with choice of different resistor combination. It onlly saves you the effort of manually cycling the power. It extends the life of the power supply fan.
Does not automate water change..LOL.
As I have said in the other site I posted this: Use it or trash it.
