Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
xbox hacker
Quote from: insane4evr on August 30, 2008, 12:41:34 PM
Hi xbox,
Thanks for the info. I notice that you are using a PC power supply in your setup. Here is a simple power cycler I am using. It will not do the various preset on/off times in the DL document. It has a fixed on time and off time you can change with choice of different resistor combination. It onlly saves you the effort of manually cycling the power. It extends the life of the power supply fan.
Does not automate water change..LOL.
As I have said in the other site I posted this: Use it or trash it.
Its not a PC power supply....its for a arcade game..LOL  ;D It has 12VDC, 5VDC & -5VDC thats all...
Great work on the Auto conditioner information!! I think i will have to try it  ;D
professor
Hi xbox hacker
Very impressive production for one Tube.Congratulations,well done .
Did you try using Distilled Water ?
My voltage across the cell stays somewhat higher with distilled Water,mind you I am using a smaller Probe with short Electrodes just for testing.
Have tried different frequencies and Voltages  also tried 2100VDC  and frequency switched Microwave Oven Transformer  with a SSR .
Production maybe 1/10th of yours.
I concluded as others that it has little to do with Voltage.
Did you tune your tubes? I mean match them for audible resonance ?
Maybe you lucked out and the switching frequency of your Powersupply matched the resonant choke and series capacitance.
My next step is using a Bifiliar Choke .
Now that you have your Circuit up and running fine it would be interesting to see what happens if you were to bypass the Choke.
If the production diminishes then thats another definite proof of the choke's necessity.
Also if you wound another one with more turns ....What would happen ?
The Answers to that could be extremely helpful for all of us.
Professor
Quote from: xbox hacker on August 29, 2008, 08:23:15 PM
Hey everyone...i got my setup running and made a quick and dirty vid with my cell phone. Please let me know what you think.
- Normal Tap Water!
- 12VDC from a switching power supply
- About 600mA at start of test
- Cell is about 2.8VDC
- Cell is SS tube...kinda small, but i am broke :)
- Top of chamber opacity high within seconds
- Dave Lawton Style PWM
- 100 turn Bifilar coil
- The extra board is the optoisalator to protect my PWM...i killed 2 555's and some resistors already!!
- NO cell conditioning! I will take test to see if the conditioning makes more gas or not.
I WILL make a new video soon, after Labor Day weekend. I just wanted to get this on film quick.
http://uk.youtube.com/watch?v=Yy-pyfw_2Pw
xbox hacker
Quote from: professor on August 30, 2008, 07:34:35 PM
Hi xbox hacker
Professor
Others have mentioned that the bifilar coil lowers the amps...its even listed on JLNlabs.org....and i have some proof. I made a new vid :)
http://uk.youtube.com/watch?v=WjcyxoYDQK4
No
No...I just slapped some tubes together...LOL
xbox hacker
@everyone:
What should a good target MMW be? What do ya think meyer got for a MMW?
forest
Quote from: Jamie on August 26, 2008, 10:54:09 PM
He heated the water before the injectors? I always thought that Stan thought heat was not very efficient. Huh.
A bit about locking onto resonance from Zero Fossil Fuels:
http://www.youtube.com/watch?v=vKjUzsNj8NM&feature=related
Blue is the waveform into are VIC transformer in the picture below.
Red is the waveform out of the transformer.
My question is, are only the negative voltage spikes being used? The positive spikes don't occur (on VIC side) because the blocking diode won't allow it, therefore the positive EMF drops across the wire connected to the PWM instead. Making the square wave kinda trail off on the PWM side, correct? Isn't this a waste? or do I have something confused. Note: I do not have an oscillascope. This is theory, I haven't actually seen this.
PLEASE SOMEONE WITH SCOPE! Put true outputs from transformer:
- powered by square wave positive
- powered by square wave but crossing zero (positive and negative symmetrical)
- sinewave
- sinewave half-rectified
- sinewave fully-rectified
I know that I please for much but I have a reason.This is very important. Please help us ! I have no scope too, but I have some idea I'd like to share and prove/disprove.
You help will be very appreciated!
Boguslaw
