Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
ashtweth_nihilisti
I think i couldn't give a frog fat ass what neither of you type on your keyboards.
Happy testing.
Ashtweth
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
Grumpy
Quote from: ashtweth_nihilisti on January 22, 2009, 07:34:41 PM
Given to me by a reliable source who wants to remain nameless. Thanks
to our friend.
Ash
Meyer used water mist that he pulsed with his dual-layered multispool
VIC(10.4), this way he avoided the stability trouble of water liquid´s
dielectric constant and the voltage breadown in liquid water. AND
REMEMBER Hydroxy HAS A SURPLUS OF ELECTRONS THAT YOU SHOULD USE WELL
AND THAT STAN NEVER MENTIONS...
Then Stan needed a positive ion to match Hydroxy with and he found out
he could prime oxygen in ambient air up until O4+ with his VIC(gas gun
app) in combination with an electron extraction circuit(EEC) and a
laser. Then he mixed it and ignited the whole mix with his voltage
igniter(VIC again). The steam resonator possibly was used to increase
or dampen the effect inside the cylinder but I am not sure about it.
Conclusion is Stan achieved at least OU of 50(maybe >100) with his ION
ENGINE and the big secret is Hydroxy being negatively charged that can
be used for the ion implosion.
At this stage I realize his car engine is a massive project of
miniparts to finish and the dual-layerred multispool VIC is a very
good start to prove his concept.
I urge everyone to wind the dual-layerred multispool VIC of 10.4 ASAP
to prove the concept.
AND I believe when you pulse the multispool VIC you only need ONE
PULSE from the primary, then the multispool backEMFs will do the work
for you until voltage breakdown, and they will come much faster than
the primary pulse too, hte more spools the faster and smaller Back-EMFs.
So basically in liquid water he needed one pulse with duration about
0.1 ms, then wait 3 secs and then send a new primary pulse. Hydroxy
will flow like crazy I guess and resonance will not be a big trouble
with the multispool VIC.
OU should be AT LEAST 10 if you have at least 4 spools.
Meyer really fooled a lot of people with all his fancy talk about
injectors, gas guns, gas processors, EECs etc, etc, nobody understood
was he was talking about. The core of his concept is a positive ion
and a negative ion, mix them and ignite. Use the multispool VIC for
better effect and less trouble with diodes because each back EMF is
much smaller than the first primary pulse so the diode can last.
So this is why I suggest that you build the WFC 10.4 drawing. Inner
core is SS430FR wire with ie 4 spools bifillary wound. Outside
isnormal magnetic qwire in 3 layers. Between each spool you will need
a diode for one inductor.
Wind the magnetic wire after secondary, continue with the SS430FR wire
in series and then go to water gap.
Thanks for any feedback on this idea. Please share it with as many
people as possible.
Good luck!
I spent 8 hours on the bench today - so shove your groundless comment, Ash.
According to the forum, Hartiberlin started this thread.  Why would he need to make a anonymous post on his own forum?
Want some more?
1. Steam (water vapour) has a dielectric constant of about 1.007 - just above air - so the crap about Meyer and his seam is BS.
2. This person has no idea why a laser is used - or the wavelength of the spectrum required - not just any laser will work or any light.
3. This person does not know the true function of the VIC, or the waveform at the cell.  The applied waveform shown as stepped pulses is not what occurs at the cell.  Also, this person does not know why the cell is pulsed the way it is or the pulse durations.
4. There is a single specific reason to use high resistance wire and it has never been uttered on any forum - this person does not know why current had to be limited to such a degree.
5. This person is spouting BS about the BEMF too - he would know if he even bothered to simulate the VIC.
6. Steam resonator was to warm the water to allow use in winter - this from Meyer's writings.
7.  No mention of what gtnt is or means.
8.  No mention of universal energy.
9.  No mention of the piezo elements.
10. the fact that he even mentions "ions" shows his ignorance.  This is not electrolysis and it is not ionization.
Go ahead Ash, follow your leader.
        -Frank Edwards
ashtweth_nihilisti
The person whio sent me this info was not Stefan, so again your waay off dumb ass.
Have you tested what was said no? Then comment on it when you have, thats what i said.
Shove my comments about this? HUH? Then your incredulous assumptions mean your ass is ignored by me, congrats..join the list at OU forum ignored by me.
Have fun in the lab mate. This forum is full of assholes like you , why do you think most of the real work is done else where.
Ash
Grumpy
Quote from: ashtweth_nihilisti on January 22, 2009, 11:32:56 PM
Ash
Glen, you as much of an idiotic ass as that whole asshole non-energetic forum  - you must hold a high office there as "king asshole of turd mountain".  Sure as hell isn't any real work accomplished over there or a Pompass-ass-acea.  Buzz tried to tell you the secret, but they kicked him off the forum - that's "real work", isn't it?
The person that wrote this BS hasn't even tested it, but you pass it off like sheets of music from an angle - dumbass.  It only take an hour or two to determine that Stan probably never used SS wire and only thought it would be beneficial - dumbass.  Once you finally figure out why he kep the current out, you won't need ss wire, but you never will with your head up your arse sideways.
Dumbass wanna-be  - peddle that worthless SS wire and that worthless false explanation that requires ss wire somewhere else.
        -Frank Edwards
ashtweth_nihilisti
You wouldn't be able to find your arse with both hands check your lab results to confirm this. .Say hello to ignored.  Spend more time not guessing who sent me info and doing lab tests
even tho you might be as wrong in both counts LOL
And less time with the Ad hom dumb ass comments, at least mine was justified by showing how you cannot guess, when i post info, it must be explored, it does not  need you come in and make your guesses which are ALL wrong.I prefer a BETTER approach. Plus my posts dojnt need many other things contributed by you that i don't need to relay which are wrong.Take my advice. trust me on that DUMB ASS.
AND never criticize the energetic forum to me, ill take you to the wall BOY.
I have some dignity. And ATM i think i have said enough about you.
Happy testing dick head,
Ashtweth.
