Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
Gheller J
Point less throwing insults at each other  and Grumpy you should probably go through Stan's Full Tech Brief to understand what the SS430 is being used for, ignorance and coming to conclusions without having the whole picture doesnt get anyone anywhere, for your convenience im attaching the particular configuration from page 200 of the tech brief so you could come to your own conclusions. got it from the same source Ashtweth is talking about.
Gh. J.
Quote from: ashtweth_nihilisti on January 23, 2009, 12:07:08 AM
You wouldn't be able to find your arse with both hands check your lab results to confirm this. .Say hello to ignored.  Spend more time not guessing who sent me info and doing lab tests
even tho you might be as wrong in both counts LOL
And less time with the Ad hom dumb ass comments, at least mine was justified by showing how you cannot guess, when i post info, it must be explored, it does not  need you come in and make your guesses which are ALL wrong.I prefer a BETTER approach. Plus my posts dojnt need many other things contributed by you that i don't need to relay which are wrong.Take my advice. trust me on that DUMB ASS.
AND never criticize the energetic forum to me, ill take you to the wall BOY.
I have some dignity. And ATM i think i have said enough about you.
Happy testing dick head,
Ashtweth.
Grumpy
Ashtweth.
Keep pissing in the wind, Glen Palise the Ash-hole.   A dumbass prick like you will never figure it out, so take your ss wire and wrap it around your neck like a noose, or shove it up you arse - you'd probably like that better - prick.
Take me to the wall - ROFLMFAO!!!  YOU HAVE NOTHING PUNK!!!
My lab results show a gas with unusually high energy - what do yours show?
        -Frank Edwards
Grumpy
Quote from: TheBuzz on January 23, 2009, 08:59:30 AM
You can see a drive motor and a pulse generator. On the end of the pulse generator you see that it has 8 poles. We also see a variac behind the pulse generator and a box to the left side. The variac is possibly being used as an adjustable choke. We see two wires going to the base of the cell and due to the ease of the twisting they appear to be copper.
It is possible that a low voltage current source was placed across the cell with the low positive voltage side and then the ground side pulsed negative high voltage which would reverse current flow and produce "particle oscillation" and electron clustering on the cathode due to the cavitation of the current/voltage reversal. But who really knows?
Learning more about that rotary pulse generator is a good place to start since it is one of the first patents that Meyer filed on this subject.
The dual layered multispool transformer is most likely a much higher frequency evolution that came later after the pulse generator went away. It appears to be acting like a modulator - See Puharich patent. But then the pulse generator itself is acting somewhat like a modulator as well.
First we need to find the "effect" then perfect it. Meyer spoke of some goofy "rubber band effect" That process I just mentioned would probably fill that requirement as well and the effect would probably cause acceleration.
The million dollar question is: "What is inside the box to the left of the pulse generator?"
1. A transformer of some sort to drive piezo bolts going into the center bottom tubes?
2. A gas discharge lamp to consume electrons from the water?
3. Who knows?
"Nobody ever thought of using an accelerator before" - Stan Meyer
On the mark Buzz.  You are wasting your time.  Only a handful here are worth helping and they can be emailed or PM'd.
Piss on these pricks.
They haven't earned it, and they don't deserve it, so, like my brother says - "They can either figure it out, or stay behind."
        -Frank Edwards
lefferdink
Hi Grumpy:  Would you please show your work.  If it cannot be posted on this forum I have an email address.
I have built the Meyers Cell, the Lawton circuit, and the bipolar inductors and still need more output.  The bipolar inductors heat up should a person put too many amps behind it from the PWM.(or even two of them).
I believe that the bipolar inductors are to be hooked up to the alternator circuit.
Will start back on the alternator circuit this week, I hope.
Regards, you all
dankie
So one of my customers probably contacted Ashtweth , I have no connection to Ash and often insulted him @ energeticforum.com . But thx Ashtweth for defending a good cause , you are finally seeing the truth .
@ Grumpy
Seriously I wonder what is it you do here , you have no work to show , no useful info , besides sharing your opinions what is it you do here  ? Cant you see I'm trying to build something positive here , but you would rather trash me because its more important for you to be right and feel smart then solving this Meyers's thing . Do ya  you see this is more important than you being right , in that little mind of yours ? DO YA ??????
How bout some encouragement grumpy ??
Everybody who works hard @ it deserves this technology , its you that is being left behind .
