Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
dutchy1966
Gheller J,
Thanks for the updated D14 !!!  Matches very well with the electron extraction Stanley was using.....
It seems this WFC is gonna be totally uncovered soon.....
Regards,
Robert
tao
I have a high res picture of Dave's light bulb that he is lighting with his Electron Extraction Circuit.
I will post it in some hours, when I get to my other computer, and attach it to this post.
Just to let you guys SEE it working too ;)...
tao
Regarding the "slots" that are supposed to be on the tubes in Meyer's demo WFC....
I posted this some months back, but felt the need to do so again regarding the recent update of the d14.pdf
Here is an image I made showing why there are NO SLOTS CUT in Meyer's SS tubes...
They appear to be merely spacers that are easily removable.
Think of a a U-shaped plastic clip.
It just an 'easy to remove' spacer, that is all. The evidence is in the picture...
Click the image to zoom in.
RunningBare
While I have used the pulse circuit from D14 and it does work, it does have a flaw in it, the way the mark/space controls are wired also cause a change in frequency when adjusting mark/space.
The circuit below is very similar to D14 with a couple of acceptions, firstly the mark/space controls VR1 and VR3 are rewired so that they have negligable effect on the frequency, secondly instead of the frequency controls VR2 and VR4 being connected to the 555 timers pin 3 output they are instead taken straight to the positive line, I've not completed the circuit because the rest is basically the same as D14, if you have any questions please ask.
Edit to add, the multiple timing capacitors can be wired as per D14, I just put a single timing capacitor on each timer for drawing simplicity.
AhuraMazda
Is the tube in the middle of the arrangement larger than the rest?
