Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
Gheller J
Runningbare>>>>>>
Cant reach your site>>>>>> hope the spooks havent gotten it down!
Gh. J.
RunningBare
I might have something soon, but since the walls of my tubes are much thinner than Ravi's I have to proceed with conditioning at lower power levels, I need to get at least a couple of layers before increasing the power or the tubes are going to be eaten.
Btw, for anyone who wants to do a reaction process difference between straight DC and Pulsed DC, use a rheostat capable of handling 10 watts in series with the cells connected straight to the supply, adjust rheostat until current reads 0.5 amps then check the HHO flow, then remove the rheostat, and connect cells to the pulser and adjust it for the same current reading of 0.5, this way you can see if there is any discernible increase in HHO output for the same power input.
Quote from: Gheller J on September 08, 2007, 11:27:55 AM
No Posts at all?????????????? ???
Cmon ppl has any1 got any tubes conditioned?? :-\
Gh. J.
Gheller J
Runningbare>>>>
If d 300 series SS grade ur usin is SS 304L or 316L there wouldnt be corrosion>>>>>unless theres acidic impurity in d water which aids in pickling of SS
If its from 400 series of SS...... theres no nickel !  >>>>>  u'll corrode d tubes any which ways!
NEW VIDEOS by HYDROCARS posted on oupower thread:
Posted: Sat Sep 08, 2007 11:36 am    Post subject:
i think i hot these in the right order
http://www.youtube.com/watch?v=56Lcyp8X75g
http://www.youtube.com/watch?v=Tf7uaPylkgo
http://www.youtube.com/watch?v=tBAk6xlcOYg
http://www.youtube.com/watch?v=IdCLdv9Nhfs
http://www.youtube.com/watch?v=x62E-ZjnUD8
youtube is doing a sorry job, this was over 8 hours ago i uploaded this.
still not in the search box!
i dont know how to make the videos public?
_________________
316L 1" OD outside tube, 3/4 OD inside Tube, 5 1/2 Tall Seamless and annealed
"LOOKS LIKE WE HAVE ANOTHER SUCCESS!!"  Check d vids urself!!
Gh. J.       ;D
RunningBare
Hey guys, regarding the bifilar wound inductor coil, I did a little research into Tesla's bifilar wound coil...
http://en.wikipedia.org/wiki/Bifilar_coil#Description_and_applications
Some bifilars have adjacent coils in which the convolutions are arranged so that the potential difference is magnified (i.e., the current flows in same parallel direction). The magnetic field created by one winding is multiplied with that created by the other, resulting in a greater net magnetic field.
Now it seemed to me that Tesla's method of the coil connection would work better, so I constructed a bifilar on the ferrite rod as per instructions, only this time I tied one output to the input of the other like so...
The reason being is that apparantly the magnetic field is stronger, so in theory the collapsing magnetic field would create a greater voltage spike, I tried my construction and there is a noticeable increase in reaction for the same voltage/current used, do not take my word for it, give it a try, I've only constructed one bifilar so far, the other tube lead has the single winding coil on it, the bifilar is constructed with 100 turns.
srawofni
RE: tao
I read your post regarding the slots in the tubes of the Stanley Meyer water fuel cell.
The removable spacer idea does have a lot of merit, but is not the case here.
The attached picture clearly shows there are slots in the tubes, light can be seen though
the slots eliminating the possibility of it being a spacer.
I refer to these as termination slots.
Cheers
srawofni
