Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
gilles
Quote from: Gheller J on September 07, 2007, 04:54:36 AM
                         WFC   WHITE  POWDERY  COAT  FROM  CONDITIONING
                          http://www.youtube.com/watch?v=Rx2uEsbTt8Y
Aaron says its Calcium Oxide
>>>>>some ppl are tryin 2 use RO and distilled water for conditionin
>>>>>you don have calcium mineral in them
>>>>>so jus use TAP water ONLY or collect water from free flowing streams could work better than tap water!!!
Gh. J.
I think it is not Calcium Oxide in my case as I also have tried conditioning with distilled water and seeing the oxide layer forming within an hour. As most sources say, it is Magnesium oxide that forms as a protective layer on stainless steel. Then again I am not sure. might be different coating using different prcedures. When i used higher amps and tap water and water got hot, then the white calc formed was pretty nasty. It formed unevenly and at certain places even filled the whole gap between tubes. So i think it is Calcium from tap water when u overheat your tubes and effect is similar to the effect of usual water heater.
Anyways, had also a maybe silly thought of just making some test tubes and try to coat with different materials and see if the effect might be similar to conditioning.... havent put it into practice yet.
RunningBare
For the last couple of days I've been monitoring and adjusting the voltage and current while conditioning the tubes, always maintaining around 12.5 volts at 300ma, removing the tubes around every thirty minutes to dry them gently over a stove.
the oxide layer is now quite thick on the inner tubes and a greyish white, but whats interesting is that the more I condition the tubes the more frequent the larger hydrogen bubbles are becoming.
djctek
Hey guys, I was bored so I decided to build the PWM in the updated d.14 pdf. I prototyped the circuit board and had it sent out to be fabricated, I figured while I was at it and put in so much time locating all the components I may as well build a few and offer a few as kits for the folks that would like one. I built 4 units, and have 4 units in a kit form. this is all I have available. If anyone is interested they are all listed on eBay and can be found with a search for "hydrogen PWM gated" , or user id djctek under advanced search. Please don't take this as spam. I am not in it for the money, I will not recover all the time and funds put into this project. I am just trying to help the people who do not have the knowledge, time or electronic experience to build there own. Thank you - djctek  ;D
behind this mask is an idea, Mr Creedy, and ideas...are bullet proof
tao
Damn dude, that is awesome looking. Good job.
Very clean and crisp...
