Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
esaruoho
esaruoho
message from ravi raju (via panacea-bocaf - which is one direction to send info to, anonymously or with your name):
"The main reason why I wanted to free source this process was to be used for vehicles as this unit cannot / would not be allowed to be sold commercially....as it can give you atleast 50% gain in mileage!....this would reduce the world automobile pollution problem drastically.....power generation through an ICE is not that feasible due to the high wear pertaining to automobile engines when used continuously for months together....as per my calculations the engine needs a re-bore every two months if used continuously!!....so the only viable alternative is to use in small Turbines. For backup gensets IC Engines could be OK.
When connecting to an ICE there are a lot of minor to major modifications and tuneups need to be done depending on the engine type and year of make. Once
Ask people on the forum to follow the Conditioning procedure that I gave as you get very uneven coat formation on the surface if you use High Amps for long periods....and when you go above 3 Amps theres a possibility of the coating flaking off...the bonding between layers would not be that strong....these layers form one over the other after every cycle of conditioning.......the small time high Amp conditioning gives you an uneven coat and the long time low Amp conditioning evens out this....more or less. The longer you use Low Amp conditioning the better the end outputs!
DONOT CONDITION ON A SINGLE HIGH AMP VALUE FOR LONG TIME.
You could end up blocking the space in between the tubes and you'll have to dismantle the pipes and start all over again. We dont yet know exactly as to what the coating comprises of! As there are some High Voltage discharges (Probably....reason...glow in the dark) they could be some  very exotic alloy compositions formed....as the temperatures for a fraction of a second at the point of discharge go into thousands of degrees C.
You could use my name and post this info on overunity.com....maybe then people would take the procedure seriously.
trol
Sugerencia:
Considerando que Stanley, al momento de patentar su ?invento? necesit? ser lo suficientemente certero como para incluir en su patente aspectos que resultaran indiscutibles, pues de otra forma se invalida su derecho, recomiendo remitirse a  su trabajo; esto es , olvidarse del ?condicionamiento? y enfocar el esfuerzo en determinar la capacitancia e inductancia del circuito secundario. A partir de ello, y de la frecuencia natural de los cilindros (que deben ser la misma), hacer funcionar el sistema; creo que por ah? va la cosa.
Los intereses que hay tras la masificaci?n de un proyecto que implique obtener un output superior a un input son tan grandes, que no me llamar?a la atenci?n que ?ravy? estuviera al servicio de los petroleros.
Pi?nsenlo, y prueben conforme a lo descrito en la patente de Stanley
leeroyjenkinsii
I bought the above device.  I know next to nothing about electronics.  I am basically a dummy with a credit card...lmao.  Hopefully I can learn some of this stuff though.  I'll let you guys know my experience with the device outside of my own personal idiot factor.
Is there a way to separate the HHO into H and 0 and then use just the H in a fuel cell?  I wonder if by doing that you could achieve immediate overunity without an engine?
peter from oz
Hello All, better to ask a silly question than make a silly mistake
Assembling tubes -as per D14- outer tubes welded to plate and singlely(?) wired up therefor arent they all live together because they are all welded together and so could'nt l have one connection or ss band around pipes all joined thus not needing to get RE annealed because of no heat stress in welding. Also the extra pipe hanging out of the inner pipe could it not be drilled and tapped for neg connection, thus not needing welding and Re annealing of pipes?
A bit like the connection on this site
http://www.youtube.com/watch?v=Rx2uEsbTt8Y
Even if they still need to be individual wires (for heat dissipation or current or?) could they not be individually attatched at point of contact on ss band? Seems a way to avoid some unnessesary steps or a bit easier in construction.
Also just got my 316L with 1mm gap alround and l found some useless zip ties (not strong enough if you put too much pressure on ) but are perfect to slide down as spacers with a little knob on top so you dont lose them down the pipe.
What else - cheap pipe cutter from Hardware cuts the tube nicely, take it easy cause there only meant for copper, no need for heat to cut so no need for RE annealing, l presume
Am also looking at above complete BLACK BOX
enough enough
peter
