Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
ravzz
Hi everyone,
I've uploaded two more videos with the new leads connected up until the bottom of the WFC.
A lot of small bubble generation this time around. WFC gets fogged up. Need to check if there's any improvement in the outputs. The leads dont get hot....but need to check with prolonged use.
WFC leaking...so cant do the gas output test right now. This thing will take time I guess.
1. http://www.youtube.com/watch?v=-WsKOdxLIJU
2. http://www.youtube.com/watch?v=u9XrLOudwRw
Stefan i'll try and do what you asked me to once the leaks are rectified.
Feed back would be appreciated and any ideas on doing something else to the WFC to improve efficiency further.
Ravi
ravzz
The following images were taken when I was conditioning the WFC a few months ago. Initially the outputs remained ver very low but gradually increased with the conditioning progressing...
Don't worry if the generation is low at the beginning
First pic is conditioning at 2 Amps.
Second pic is scum on the surface in between conditioning.
Third pic is scum at the end of the conditioning...when you need to change the water for the next round of conditioning.
Fourth pic is generation at 5 Amps.
Fifth pic is scum again
Sixth and Seventh pics are the scum holding on to the tube edges which need to be cleaned with a brush only...do not touch the pipes with bare hands.
Ravi
hartiberlin
Quote from: ravzz on August 24, 2007, 04:08:25 AM
Ravi
Is this just 12 Volts x 0.5amps = 6 Watts only ?
Really ? if yes, you really have a huge gas output for
such a low input power...
Do you have a scope and can show the waveforms
at each pipe pair ?
What frequency do you use and can you also show
your chokes ?
Why do you power each pipe pair individually and don?t
put them all in parallel at the device , so why are you using
so many wires there ?
Regards, Stefan.
ravzz
Hi Stefan,
Yes the current draw by the freq gen is 12V 0.5 Amps its from 12 Volt 10 Amp DC converter that I use. The current reading you see is the input draw to the freq gen from the DC converter. Everything you need to make this unit is in the updated D14.pdf in the link below
http://panaceauniversity.org/D14.pdf
including the inductors....which are very very important. Then comes the conditioning which is crucial....how to is posted on oupower. Its a specific procedure that has to be followed!
Dave who was the first to replicate stan meyer system had got outputs in the range of 250% OU (without the inductors, should be more now...he hasnt talked about the outputs with the inductors). I have made my system based on his inputs and all these inputs on how you can get these kind of outputs are already posted on the oupower forum and partially here.
No I dont have a scope. My system was slightly modified and I have so many leads going in as I can control the number of tubes that can be operated without opening the WFC. I have 18 leads coming out of the WFC 9 +ve and 9 -ve.....with this I can run on one tube or six like daves or all 9....you basically have an easier control on the number of tubes to be used for experimentation without dismantling the WFC. Dave's and Stanleys systems had a spacing of 1/16" (1.5875mm) and my pipes have a gap of less than 0.670mm (could be the main reason for the higher efficiency in my unit) and im using 9 tube sets of 9" length and the inner being 1/2" more than the outer for connections. Dave used 6 tubes of 5" length for his 250% OU. Stans were 9 tubes of 18" length on his demonstration electrolyzer and in one of the videos available, there are claims that he's making 1700% OU over Faradays. When compared to this efficiency I still have some more work to do. Dave's electrolyzer generating HHO with inductors as per the updated D14..... video link...
http://www.youtube.com/watch?v=OiA4z_Kpgg4
Stefan the excess gas outputs were documented quite sometime ago by Dave. There are a few people who have connected the D14 system to vehicles.....here's a link....this guy claims his mileage increased from 28 miles/gal to 45 miles/gal....thats an increase of 17 miles per gallon.....he's even showing you how you can tune a WFC with an AM Radio!!...
http://www.youtube.com/watch?v=9fFp3CJZMTw
Everything you need to make this system is in D14 and the data which is required to make this system efficient and how to go about it has been posted by me on the oupower and here. You get very very low gas generation in the beginning when you are conditioning like you see in the pictures above and below. I dont know why it works the way it works or the theory behind why or how it works.......it just works!......Make it follow the procedure and you will achieve OU over fardays!!! I've put in efforts without thinking it would fail and it didnt...
Im posting a few pictures of WFC under construction and progress....
The wall thickness of both the pipes is 14 SWG or 2.032 mm
Ravi
ravzz
I'm unable to connect to oupower.....incase someone can get through....the info & data could be copy pasted here...
Just incase.....
