Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
RunningBare
I thought for a moment the spooks had got overunity.com! ;-)
Copied from posts I made in another forum...
Who am I kidding!, it has taken 1 hour 25 minutes to inflate the latex glove to the point where it is standing upright with just a little under 6 watts, I can do better than that just eating a tin of beans!
Heres something interesting, I removed the two separate inductors that were feeding the tubes and replaced with my bifilar wound ferrite core transformer, the number of windings are the same in each case, where each of the ferrite inductors were fed one to the outer tube the other to the inner tube, I did the same with the transformer, each of the windings is open ended at the input and output, so I connected the input ones, one to the positive rail the other to the pulse output, the outputs were then connected one to the outer tube the other to the inner tube.
Original separate inductors, these were wound on separate ferrite cores
pulse ---ccccc-----  inner tube
pos   ---ccccc----- outer tube
bifilar wound transformer, these were wound on a single ferrite transformer core.
pulse ---ccccc---- inner tube
pos   ---ccccc---- outer tube
Both windings wound in same direction
It took 1 hour 15 minutes to fill the latex glove with the same power input but using the above transformer arrangement, thats a full 10 minutes less than the original setup.
djctek
Due to the numerous requests I have had for it -
I just listed 10 more of the PWM "black box" on eBay as a preorder sale - Item number: 120163570832  - the pcb's are off to manufacturing and have a delivery eta of 9/24 unless they get them done quicker and the box will start shipping on 9/25/07
Thanks guys
behind this mask is an idea, Mr Creedy, and ideas...are bullet proof
ashtweth_nihilisti
I really wish some one would do up Kits and put all revenue back into this research.
I would consider doing this, I represent a non profit org, and dot need money but engineers (open sourced) do. Our circuit is 90% done Guys.
We are making a step by step of Ravi's replication and all processes he mentions, hopefully this will help beginners.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
hansvonlieven
G'day leeroyjenkinsii and all,
Quote from: leeroyjenkinsii on September 18, 2007, 12:14:42 AM
I think another example of what Stan Meyers is talking about is the Kanzius affect.  So the radio waves cause the water to split with the salt serving as a catalyst.  Once the water is turned into HHO and it is lit, it starts to attempt to combine back into water.  This would usually lead to a small explosion and the recreation of water but that does not happen in the Kanzius experiments.  Instead as the HHO attempts to form H2O it is unable to do this because the radio waves are exciting the gas and it is staying in a plasma state giving off 3000 degrees heat as Stan Meyer's said.
Is anyone working on a Kanzius recreation?
Yes, I am. Both Stanley Meyer and Kanzius got their inspiration from Keely.
If you want to have a closer look at what is involved a little background reading on Keely will not hurt. A good place to start is my website.   PLUG-PLUG :-)            http://www.keelytech.com
Together with a couple of guys I am at the moment attempting to design a device with the following parameters.
An AM transmitter that can be tuned to operate on a carrier frequency of between 40 and 45 KHz. Into this we feed an audio signal that is composed of certain chords a la Keely via the audio output port of a computer.
The resultant wave form is then fed into a quantity of water inside a resonant cavity.
If anyone is interested to help with this project please contact me through my website.
Hans von Lieven
