Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
albator10
Hi,
Can someone check the value of this circuit ?
In German, sorry, but I am sure that the symbol are universal.
atlantex
Hi RunningBare,
QuoteI hope you wont take my criticism in the wrong way, you are going have incredible instability problems because the leads feeding the chip timers are too long, you need to get the componants as close to the timers as possible keeping all leads as short as possible, especially the input leads pins 2, 4, and 6 of the timer chips, you should get the timing resistors and capacitors as close to these pins as is physically possible, its not so much of a problem for the gating part as that is low frequency, but the high frequency part is quite critical, the long leads on the input pins will behave like antennas causing the circuit to be unstable.
no problem, good advices are always welcome, I'll try to shorten some of the criticle cabels. I also have the possibillity to create PCB's, so it would be nice if you could post an updated pcb shematic.
stay tuned
atlantex
atlantex
HiHo,
first test is still running, what I noticed.
- one coil is ticking while power is switched on
- the current on the ampmeter is jumping (ampmeter right after the power supply)
I'll do some pictures and post those here.
atlantex
Gheller J
MULTIPLE BIFILAR SETUP for WFC!!
Quote from the sender:
Im sending a pic of the multiple bifilars I tried on the WFC just a while ago. These were connected to each pipe individually. Diode used 1200 V 40 Amps. Solid core length 8" wound with 0.711 mm conductor end to end.
The generation increased by approximately another 10cc of gas for a 20 second period.
This works on efficiency!! Need to try out other combos to see if it can increase some more.
Gh. J.
RunningBare
Are you connecting those the way Ravi advised?
Quote from: Gheller J on September 22, 2007, 11:21:46 AM
Gh. J.
