Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
leeroyjenkinsii
Dutchy that's a nice box you got there.  Is anyone making tubes, etc. and selling them yet?
leeroyjenkinsii
You mean this link?
http://www.youtube.com/watch?v=94KzmB2bI7s
I have read that there are tales of ancient civilizations that could move tons of materials with sound.  I don't know if it's true or not, but clearly something odds going on in that chamber.  Supposedly Keely did this very thing.
I figure a resonant chamber is a resonant chamber.  Perhaps it applies to the Stan Meyer scenario?  Also, someone posted something about the guy from h2earth talking about all of these overunity possibilites relating to resonance.
Would the creation of  laser light be a type of resonance?  Basically the light is bounced back and forth between mirrors in a substance until it finally escapes through a hole and TADAH...odd things happen.
If you think about it...in the Kanzius experiment, perhaps the testube is resonating??  I don't know...just blabbing on and on here.
djctek
Peter from OZ, Sorry to hear about your mishap, I would think it should have blown the fuse before it fried the mosfet, interesting?
if any one else has a problem with the unit please let me know. Feedback is the only way to make things better, I will repair any unit
that quits working for free for the first 60 days for the cost of parts and shipping. If you are going to run the unit for long periods of time it might be wise to place a small fan blowing on it. Under my tests at low amperage, the mosfet remained cool, if you crank it up it will get hot!
ALSO UNDER NO CIRCUMSTANCES HOOK UP THE POSITIVE AND NEGATIVE INPUT BACKWARDS, IE REVERSE POLARITY,
I CANT STRESS THIS ENOUGH, IT WILL FRY THE 1N4007 DIODE IN A HEARTBEAT.
If you do or did, you will know what is wrong with it.
I listed a few more of these on eBay, for anyone who missed out on the last auction, item  # 120165493869
behind this mask is an idea, Mr Creedy, and ideas...are bullet proof
Gheller J
More info on Multiple bifilars
Gh. J.
Forwarded msg
I think my tubes are still being conditioned as I saw a lot of brown stuff generation when I connected the bifilar inductors. The conditioning I presume happens for every specific voltage.
Try to use a ferrite core torroidal to step up voltage connect to the inductors (individual and regular wound) as mentioned by Spewing on Overunity thread as of now as the bifilars are creating some problems...I blew up both the 1200V 40A diodes....looks like one of the tubes ( no.7) has shorted...no gas production. The voltages might have gone very high with the bifilars connected and theres a possibility that this is creating problems for the smaller gap to short out. Dont use the bifilar inductors till we have a proper understanding of how they can stably work.
I'll probably have to open up the unit to see what's wrong.
atlantex
Hi folks,
I'm in the process of conditioning right now, it's intersting to see that different frequencys seems to have different effects to the gas generation, so forms a lower frequence little sparkling bubbles and a higher frequence something like fog right in the water.
Well, after 8 conditioning cycles yet, the coating of the inner pipe has startet, I can't follow the exact values as recommented in the PDF because I only have one pipeset.
After that time now, I can't say that the gas generation has increased but don't worry, I'll don't stop the process now.
I'm going to make a new new choke tomorrow, someone like ravi's bifilar coil, shorting shouldn't be a problem here, because the gap of my pipeset is ~1.5 mm  ::)  anyway, I have to try it.
good night
atlantex
