Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
0 Members and 18 Guests are viewing this topic.
RunningBare
Really nice setup Gilles, when ya gonna launch it?  ;) only kidding, I'm still waiting to get my mits on some 12 inch tubes, my present setup sucks!
I've coated the outside of my outer tubes with water proof glue so that all energy is concentrated between the gap, cannot see any improvement but no loss either, so I guess it is safe to say the insulating the outside of the outside tubes is ok, at least this will increase the life of the metal a bit.
Quote from: gilles on September 26, 2007, 05:46:31 PM
forgot to attach ...doh
Spewing
if you want to increase the life of your tubes, don't let your tubes touch as in using tie straps or fitting tubes together touching side by side, this will eat the sides of the tubes. i'm very sorry to tell you this but i just wanted you to know before you ran your tubes, if you keep running them the way they are in the picture it will eat lines running from the top all the way down to the bottom.
SORRY.
Btw, Sloted Tubes and More water will Run Cool, your tubes should be in a tank such as stanley meyers to run cool, not in a tank like mine or yours, there is no room for the tubes to breath in our tanks, and will a small amount of water it will heat up faster, a large amount of water dont heat up no where near as quick, i'm not even sure it will heat up if the tubes are vented correctly.
Those are some nice tubes, i hate to see you ruin them. if you want to keep them at a long life get a bigger tank, and bigger is better. Slots is better than one tune longer than the other, it someway circulates the water better, it also makes the hydrogen bubbles get the heak out of the way so other bubbles can take it's place, unlike the longer tube.
RunningBare
If your refering to me, my tubes have more than enough room lol http://uk.youtube.com/watch?v=rc0Hay3MBC0
Quote from: Spewing on September 26, 2007, 10:29:47 PM
SORRY.
ashtweth_nihilisti
Gills i love the smell of napalm in the morning it smells like victory  8) ;D
But the universities wont believe oyu have it running, here is a message after we told one university that Ravis and Dave's results where getting reported
""In an enclosed system the energy required to create water from hydrogen and oxygen is exactly the same as that to split water into its components (oxygen and water). The nett result is ΔG = 0. This has been known since 1873 and is well established in the Laws of Physics. It can be reviewed at http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/helmholtz.html which quite well describes the electrolysis of water and its recombination in fuel cells. Hence it would be a waste of time for the University getting involved.
Where the client may be getting efficiency (if at all), is in the electrolysis equipment as losses occur in the process, hence an audit of the efficiency of the equipment is probably all that is needed. However it would appear that this has already been done in both India and London.
Consequently I can?t see any role in this for UniQuest or the University
Looks like i need to show this guy personally..
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
