Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
peter from oz
Hello Dutchy yes the clamps are ss but the winding mechanism is gal plated, next question l spose is can you get total ss clamps, l'll try to source them.
ln the pdf or Ravi's thread it mentioned after welding or any "cold" work you would have to get the tubes annealled so l was just trying to bypass the need for this.
Peter
KISS
Stan Meyer mentioned the use of Delrin as an insulator to encapsulate the resonant cavity(57)of figure 3-25. This encapsulation(Delrin), Electrical Insulated Housing (72), appears to be bound only to the outside surface of the Positive Excitor Plate(66). Positive Excitor Plate(66)encompasses the Tubular Resonant Electrical Wave Guide Cavity (57). There appears to be no Delrin on the Negative Excitor Plate (67), nor on the inside surface of Positive Excitor Plate(66).
saintpoida
ok so i put the inductors i made for my test tube onto my 9 tube setup
and while the amps dropped the max production i can get it is very small,
the single crap tube i tested with produces way more by itself!
and the voltage across the 9 goes down to like 2.6volts
So would this mean that my indcutors are too small? Or is something else
the matter here?
I unplugged 8 of the tubes to see if it made a difference and it did the 1 tube by itself
is producing ok, still not that great but way better than when all 9 are in and nowehere near
as good as the smaller single crap tube i have
Anyone have a clue?
del_toro_es
I think that the way to archive the ?quantum jump? and approach to the performance of original Meyer cell is to obtain resonance with the water condenser circuit composed by the pipes, the coil.ad the oscilator
Anybody have some idea to calculate/measure the resonance  frequency? Resonance with sound or electrical?
Which parameter would be measured to fit the resonance frequency?  Perhaps the electrical current that is possible extract of the cell?
lucky
