Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
Visual Echo
Quote from: lefferdink on July 22, 2008, 02:07:32 PM
what type of soldering point do you use?
I use an "Aoyue 2702 SMD Professional Repair & Rework Station".  I had to get serious about some surface mount work a couple of years ago, and that station has been a terrific investment.  It is pretty cheap for how well it works.  If you actually want to start working with surface mount, plan on buying an observation microscope.
http://www.thehydrogenshop.com (referenced above) looks pretty good.  As far as I can tell, it's still just one-way PWM, no PLL closed-loop feedback is involved.  The microprocessor version is cute.  He's open about the design, that's great!
I have some pretty lofty plans if this works, like completely overbuilding the control unit.  PIC chips and ASCII LCD screens are one way, but you can get a lot more control and real estate using a microcontroller with wifi and a web server.  Here is a pic of my last project: ( http://www.darkhq.com/bb/files/pimp-a-sketch-linux.jpg ) which might become the control computer for this one (see http://www.gumstix.com/ ).  Meanwhile, I don't even have a cell working yet, much less a working PLL circuit.  Money talks and BS walks, so back to my workbench I go!
*** Visual Echo ***
ashtweth_nihilisti
Guys , we are now re drawing the VIC and putting in about the inductors, we have re drawn the schemo's and added in new and updated info.
Yes, Rod from down under is also helping us make Ravi's cell, this will be under open hours and used to support Ravi's research and other open source engineers under the Org's help.
wont be long prob 2-3 days till new doc is up.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
ashtweth_nihilisti
Here ya go guys, Ravi has advised us what to re draw for the Meyers VIC.
Ravzz' full VIC
http://img378.imageshack.us/img378/2397/completecellwiringdiagrdj9.gif
(He is proof reading it now)
http://img368.imageshack.us/img368/4058/74501320xm0.gif (inductor Schemo)
http://img368.imageshack.us/img368/4612/17573941so2.gif(Alt)
http://img70.imageshack.us/img70/7576/coldcurrentcircuitgn6.gif
(cold current)
WE will test this when our new cell is ready
http://img378.imageshack.us/img378/9173/freqgennn9.jpg
our Freq Gen
http://img212.imageshack.us/img212/7866/setup1kr8.jpg
This is our [old] cell and Freq gen too. These will be going in the
new write up, we have a guy working with us and Ravi to get this OPEN
source replication done.
Ash
Visual Echo
Beautiful!  And answers my question, thank you!!
*** Visual Echo ***
insane4evr
Ash,
Thanks for the schematic.
Some comments:
1. Even though it won't make much difference, R2 should probably be the same as R1 (100 ohms), minimizes on different resistor values.
2. Picture shows that rotary range switches are being used, i.e., S5, S6, S7 is just 1 rotary switch, so C8, C9, and C10 should probably be different values.
In my test, Q1 drain has random spikes of over 100 volts, so would be a good idea to add a capacitor between 13.8 VDC and ground if circuit is installed in a car to avoid interference with car electronics.
Impressive.
