Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
onormanns
Quote from: 4Tesla on July 30, 2008, 08:35:25 PM
I remember Meyer talking about tuning the pipes.. I think it helped.
Jason
there is two types of resonances according to my understanding, the mechanical standing sound waves - helping the bubbles to release from the surface, and the impedance tuning. you mentioned plasma electrolysis from japan i scanned it briefely, interesting wonder if we can pick up some principles onto this one.
onormanns
Jason
someone even mentioned meyer had insulation on one of the tubes. the oxydation layer is probably better, with insulation we get in to bubble problems attaching to the smoot surface.
well thank you all for responding. god speed
HeairBear
The way I see it, is, there may be multiple resonances in both the circuit/electrical and the tubes/sound. If the tubes are tuned to, let's say A @ 440 cps in the audio spectrum, the circuit can be designed to resonate at the same frequency or harmonic of the A. I suspect it has something to do with Sympathetic Vibrations. The electrical resonance, in my opinion, must be in parallel to achieve high voltage and low current. Series is just the opposite where the current is high. So how do we get a parallel resonance out of a series circuit like Stan's VIC? If we find the resonance of each coil in the circuit we also find that the coils alone can resonate with parallel characteristics. We can calculate with distributed capacitance and inductance also to find the most efficient frequency for your particular build. Each persons will be different unless we can follow a strict bill of materials to set a standard to go by. Does RAVI's circuit resonate? I may have missed that info but I didn't see it if it was in the documentation.
Stephen's patent was designed after Stan's "Voltage Sync-Pulse Circuit" on page 177 or so in the Tech Brief. Although Stephen's circuitry is much more complicated probably for obscurity as usual. Most inventors obscure their work for good reason, So it can't be easily stolen by replication and modification.
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
HeairBear
I forgot to mention a really easy experiment you can do with an ATX power supply from a computer and some distilled water without any electrolyte. The power supply will have a negative 12V line and a positive 12V line but the current for each is different. Therefore, more bubbles will come from the side with more current. You can use three tubes/plates or even two and a grounding wire, or even three wires. This is a pseudo "Voltage Sync-Pulse Circuit" but it demonstrates the idea. It can be incorporated into RAVI's design quite easily.
mostrander
HeairBear,
That is what I'm going to experiment with the + and - voltages pulsing. I'm was wondering when you did this did you get and bubles from the ground or just the + and - voltage leads?
Matt
