Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
newbie123
Little off subject, but have a look at this: http://uk.youtube.com/watch?v=rUHeBPBzca0
could the plasma version of the "diode effect" mentioned in papers previously posted.
Until you can measure it, arguing about something can be many things.. But science is not one of them.
LtBolo
@esaruoho
Thanks for making the effort. That didn't answer the real question, which was whether the clamp-on current meter was capable of DC current measurement...as many are not. I have studied the videos at length and have no doubt that the connections are correct...no problems there. It was simply the issue of whether the meter is appropriate to measure DC current.
At the least, even if it is only AC current capable, it should be somewhat accurate given that the DC load will be varying with the switched output. Clearly though, if the meter is DC current capable and the DC setting was used, his numbers should be dang close.
But again, thanks for trying. In order answer the real science questions about how and why this works it is important to have these types of questions answered. Since our silent friend is one of a very few that has demonstrated what appears to be a huge success, his apparatus clearly holds valuable information...information that you can't get unless you ask. Please extend to him a gracious 'thanks' for responding.
We read through the conditioning docs he provided, and have already performed the glow experiment with aluminum and baking soda. Worked beautifully....fascinating. Currently investigating how that applies to conditioning stainless...seems to work very poorly (very slowly) by comparison. Makes we wonder whether plating with nickel, or even using aluminum might be better than using stainless.
newbie123
Lots of heat + steam  for only 120W .. Probably some HHO in there as well.
ravzz
Alright People I just got the Newman Motor generator to work about an hour ago.
Wanted to see if theres some useful work we could get out of the High Voltage Surges if integrated to the WFC.
I used 3 x 9V batteries as source..connected two meters one straight and one in reverse to the same input..the motor generator seem to work nice but what's interesting is that I noticed a surge reach 1948 Volts! (Video grab of the surge below) there are absolutely no electronics involved in the circuit! other than the meter connections!
I hope its not instrument error....just in case I reversed both the meters in the second video.
I have no clue where these High Voltages are coming from!!....if it were actually 1900V + shouldn't I be dead??? Is it Radiant?.....I dont know!...you guys tell me.
Guys please dont ask me to post directly over here about the WFC....you know the reasons....I'll try my best to answer whatever i can through someone else till i feel its safe to interact directly.
But this was something I thought I had to get you guys to make me understand as to what was happening.
I'll brief you up on how to make the circuit and what I used later through panaceauniversity.
Videos:
http://in.youtube.com/watch?v=0MSGstC_Ykc
http://in.youtube.com/watch?v=sl_6BLfqRpQ
R.
ravzz
Scope shot by Ray0energy of his Newman Motor Generator:
http://in.youtube.com/watch?v=ofrfeyTOhYY
I was just told not use 9 Volt Transistor batteries for this as they tend to explode due to the HV surges.
R.
