Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
Jamie
My tubes are not ready to hook up. I can only get them in 20' lengths and need some time to cut them.
I was reading this:
QuoteWater resonates at 926khz, and will disassociate at that
range. Before conditioning the generator, briefly dry modiluate it in
5 second bursts, with about 2 min between bursts for about 10 min. You
should be able to hear it hum, and with a practice ear, tell if one
set is out of picth.
I am just trying to understand what makes the tubes hum (viberate).
@newbie123 I have a Dave Lawton circut, as shown in D14, that will be hooked to the tubes. I will mount them so they can viberate. I'll atleast use foam for the spacers like Ravzz.
Jamie
xbox hacker
Apply power without water, and you should hear it "resonating"...or humming. Just a guess..... ;D
newbie123
Here's a question  to consider if you're trying to build a Meyer's WFC:
In this video: http://uk.youtube.com/watch?v=M9JagAv2nUE    ... about 2:14 into it.
Where is the inside tube connected to  a wire? Is it connect to anything?
Until you can measure it, arguing about something can be many things.. But science is not one of them.
HeairBear
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
ashtweth_nihilisti
Email given to panacea
LETS FEEKEN RAWK GENTLEMEN
,our new cell with have delirin , slots and UV
I have been studying all the water fuel cell designs on the web and I have come up
with an idea why Stanly meyers and Bob boyces fuel cells work so well. The pulse
frequencies maybe hitting the electromagnetic spectrum of Ultraviolet light. I
believe the effect is ionizing the molecules of the water to help pull them apart. I
think this is why stan meyers Patents show the use of a laser in his designs. The
laser would help in the process of Ionization.
Here is some of the info I have found.
Breaking up of water into its constituent atoms is a
two step process. The first step involves pulling off the first proton to leave a
"hydroxyl radical" (represented as OH).This is the Ionizing of the
molecule  This requires a
wavelength of 243 nm or 117.59 kcal/mol
(this is in the electromagnetic spectrum of UVC light). I think that this can also
be done by adding electrolyte to the water(Dont quote me).
The second stage of turning H2O into 2H + O is the breaking up of the hydroxyl
radical which occurs at a slightly different energy and wavelength (281 nm; 101.76
kcal/mol). This is UVB Spectrum.
After this generating Hydrogen and Oxygen gas is a simple
matter involving very little energy - 1.23 volts or the aid of an
ordinary battery. After the separation of the H2 + O you just need to create a
reason for them to not to recombine. Having the electrodes in the water with a
simple battery circuit will attract the Hydrogen and Oxygen into a Gas.
I cant be credited for the science the information was posted by Todd Whitcombe,
Associate Professor, Chemistry
http://www.madsci.org/posts/archives/Mar2003/1048779104.Ph.r.html
I have only done a very simple test of this theory with electrodes in tape water. I
made a FC with metal mirrored sides to intensify the UV. Now I dont have a UV light
in the correct spectrum its around 320 nm - 340 nm. I then just connected a 6v
lantern battery to the electrodes without the UV light on. Nothing really happened.
When I turned the UV light on I noticed I started to get a stream bubbles!
I believe information should be shared to better mankind. I hope this helps the WFC
community.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
