Stanley Meyer replication with low input power
Started by hartiberlin, August 18, 2007, 04:39:57 PM
capacitor70
Quote from: sbeehre on August 19, 2008, 02:32:02 AM
and how long did it take you?
Actually I did it for only eight days. I don't have patience. then started work with plasma system
ashtweth_nihilisti
Guys unless you follow the replication instructions EXACTLY then how can you expect to get any results?
Ravzz doc is updated too.
Ash
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
sbeehre
ive been looking through the latest ravzz document and in there they are talking about using the cell as a booster to give you a 50% mileage increase... does this mean that its not capable of running a car? what i was wondering was if you had 2 or 4 cells working together would you use the same power as one but get 2 or 4 times the gas?
professor
Did you use Distilled water,Tapwater or any chemical additives?
What material are your tubes made of ? (316L Stainless?)
Thank you
Professor
Quote from: newbie123 on August 18, 2008, 10:33:21 PM
I have a very even coating in one of my experimental tube cells, and the coating is so thick it pretty much fills the whole 1.5mm gap..  I got this by using low current (minimal bubbles), with straight DC electrolysis, for 3-5 hours .. Then let dry, or use a blow dryer, then repeat .. After about 2 weeks the coating is very thick.      And it looks like a crystal formation (symmetrical) at the bottom side of the cell.
Not sure if that will lead to the same results as Lawton/Ravi but it worked well for making a thick, tough, oxide coating.
HeairBear, Thanks.
Jokker
About shot that you took  :o
Nice waveform   ::) where did u measured this signal ?
Buy the ticket !
Take the ride !
