Possible major break through, LPSS
Started by Butch LaFonte, June 06, 2005, 02:33:27 AM
prometheus_effect
Hi Stefan,
The spot torque force pulling the lower rotor CCW is very much lower than the torque force puling rotor 1 CW (back to rotor 2). Integerated over distance the two torques will equal.
The bottom line is there is no continual magnetic gradient here. Plot the flux density gradients around the loop (it is they who generate the torque the rotors feel) and you will see it is conservative.
Greg
Now its just engineering effort, time and money,
Prometheus_Effect
magpower
Yes think you are right the LPSS makes no sense to me. How each one flips then flips back and has a greater force.Maybe Butch has a simple test or demo of this. The LPSR should work 360 but the banging arms won't be good. But who cares if 360 works and works.
Wayne
Quote from: hartiberlin on June 07, 2005, 01:16:03 PM
Wayne,
I think the LPSS is much harder to build
and it is vague, if it will work.
Go first with the LPSR and yes, you can use magnetic arms.
Post some pics, when you have any results.
Thanks.
Regards, Stefan.
