weri812 core
Started by weri812, September 02, 2007, 12:16:38 AM
weri812
@ All
second dary layer done
09-23-07  new  winding ccw
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
Bruce_TPU
@ Wer
Beautiful work, my friend!
I almost can't wait to get back from my vacation and to start winding.  Are you going to wind three primaries or six?
Warm regards,
Bruce
weri812
hello Bruce  and all
had to rewind core the new core will have
6 prymarys at 20 turns each
weri812
To ALL builders
i used 20 ga wire for all 4 coils and it took  about 208 ft
all coils are ccw  but bottom one it is cw looked at Bobs pics to see direction.
i wound the center coil on a Insulated  soda can holder, soft foam type.
a tad less than 3 1/2 inches across,  then fed the wire in  one winding at a time,
i also used a 3m contact spray adhesive to hold the wires in place.  it takes a while.
thanks
wer
Thanks a bunch Weri!
I just wound 48 turns of the magnetic bias.  A bit harder to do than it looks, but it came out pretty!  I plan on winding one segment a night.
Thanks for the info...you should post it on your thread, it may help others.
Warm regards,
Bruce
  to all  i left the ends non shorted for future use.
  easyer to short  than to un tape and quicker to get to.
  all wires comming off core will have a seprate conection on the  abs plastic electrical box
  that  i will put it in it will be12x12x6" my controller  will mount on top of box
  with the 18v battery power supply that i will use.
  will also have a verable  high/low bias control. have not built that yet.
thanks
;D
weri812
 To All
  take the first picture and print useing  microsoft picture fax  viewer
  take picture draw  0-120-240 lines then 60-180-300 if using  6 coils
  put  coil on picture then daw lines
HERE ARE MY FINISHED CORES
